rear tires, axel issue or question - JeepForum.com
post #1 of 6 Old 10-11-2013, 10:54 PM Thread Starter
Dukcaln
so I got new tires today, and got home and noticed that the rear tires were different as far as sticking out from the fenders. The passenger side rear sticks out about 1/2 inch past the fender and the driver side is flush with the fender. I didn't notice this with the old set of tires but with the new it is obvious, any issues as what it could be. the wheels are all the same with same back spacing and I will go out to make sure the tires are the same. I bought the wrangler dura trac tires, 31x10-50x15.
Weird is all I can say.
but on another not, the tires look and drive great
1996 zj-v8-79k miles-corbeau seats-exhaust-hood vents-3 1/2 lift-safari rack-arb bumper-amps-subs
Dukcaln is offline
post #2 of 6 Old 10-12-2013, 12:31 AM
Sextiva
You need to check your rear track bar.
1996 GC
Sextiva is offline
post #3 of 6 Old 10-12-2013, 10:34 AM Thread Starter
Dukcaln
ok, what would I be looking for and how to adjust? would the rear track bar if it has issues cause the rear to kinda sway back and forth depending on the road conditions? all info on rear track bar pleases, is it adjustable ect...........
Dukcaln is offline
post #4 of 6 Old 10-12-2013, 04:53 PM
Kevinyj95
cant adjust it if its stock. did you put in a lift without putting in a drop bracket or adjustable track bar?
Kevinyj95 is offline
post #5 of 6 Old 10-12-2013, 04:56 PM
Kevinyj95
its a bar with a bolt to the axel and to the uniframe holds it in place. keeps it from doing what it is now.
post #6 of 6 Old 10-12-2013, 05:01 PM
Kevinyj95
A. track bar is gone or broken off. B. bushings a gone. C. vehicle has been lifted inproperly. Your going to want to look at your control arm bushings after it must have a ton of stress on them wobbling back and fourth.
