Rear tailgate - JeepForum.com
post #1 of 12 Old 07-14-2012, 05:49 AM Thread Starter
Tamistoma
Rear tailgate
Hi Guys
can anyone tell me how to open my Grand Cherokee jeep 1998 talegate, it does'nt open with the key or fob. loosed the two nuts that hold the retaining part of the lock still no joy. I would be grateful if someone could help.
Thomas
Tamistoma is offline
post #2 of 12 Old 07-14-2012, 07:39 AM
SAR-Swimmer
Have you tried pushing in on the hatch, while turning the key? There's lots of info on this problem, which is fairly common, if you do a search. Try "rear hatch jammed", in the search box found at the top left corner of this page. Sometimes, you need to open up the hatch from the inside by pulling back on the interior trim, and reaching in to be able to pull a section of the latch, that has become disconnected.
SAR-Swimmer is offline
post #3 of 12 Old 07-14-2012, 09:04 AM Thread Starter
Tamistoma
As the tail gate is in the locked position I can not remove the surround ing trim as there are screws which I can not access. I will try the seach engine.
Thank you for your assistance
Thomas
post #4 of 12 Old 07-14-2012, 12:58 PM
LordHobbit
Have a helper pull on the tailgate handle, while you, inside the jeep, kick very hard on the bottom of the gate.
No guarantees that it will work and you won't break stuff.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is online now
post #5 of 12 Old 07-14-2012, 01:03 PM
Mickey_D
Mine does this every once in a while (read : almost every time). Can you feel it unlock? If so, it's the latch bar is out of alignment. Mine I have to push down on the hatch (down, not in) and then pull the hatch open. Quite often I have to do it several times in a row for it to work.
Never thought to try the "someone pull the latch while you kick the **** out of it from the inside" trick...
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #6 of 12 Old 07-14-2012, 09:58 PM
hdrocknroll
Most likely the handle latch rod slipped,position, there are other ways to get it open if first attempts fail
See this thread
tried everything in the search and i still cant get my lift gate open
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #7 of 12 Old 07-15-2012, 05:34 AM
KoreaZJ
1994 ZJ
Better to do preventative clean/lube/adjust maintenance before it fails completely with the liftgate closed.
When that happens... you'll need to use the PolkaPower recovery method seen... HERE
KoreaZJ is offline
post #8 of 12 Old 07-15-2012, 06:42 AM Thread Starter
Tamistoma
Thank guy's for your help, fixed the tailgate this morning by removing the screw I could see from the inside tailgate panel. wedged the panel apart put my arm down and pull the rod. the locking link & the actuator rod had came off, put them back on lubed the lock and surrounding area. Furthermore I cable tied the actuator rod to the lock so it does not jump off again.
Next task is to fix the the bad sensor noise nightmare, the joy's
Thomas.
post #9 of 12 Old 07-19-2012, 01:08 PM Thread Starter
Tamistoma
Bad sensor message
Hi Guys
Just fixed the bad sensor message/noise which I know most of you dislike. What a difference it makes to your journey with out hearing it. A bit of soldering is all it took, once you dismantled most of the dash that is. just a couple more jobs to do "to thats if the talegate does'nt kill me first" (Struts are gased out my next job).
Thomas
post #10 of 12 Old 07-19-2012, 04:31 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
The OP posted "1999 grand cherokee", thats a entirely different critter than a ZJ. They latch on the sides of the gate. Maybe it was a typo.
Originally Posted by HighLonesome
coralman is offline
post #11 of 12 Old 07-19-2012, 04:57 PM
Area.3.Fiftyone
Uh, isn't this the ZJ forum?
Am I lost........again?
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #12 of 12 Old 07-22-2012, 02:05 PM Thread Starter
Tamistoma
Hi
In Scotland my Jeep in an S reg which indicates which year it was registered 1999 my mistake. My jeep is ZJ.
Fixed the tailgate struts yesterday what a difference.
Thomas
ZJ Rear tailgate way too loose kwape ZJ Grand Cherokee Forum 4 04-01-2010 12:17 AM
Rear Tailgate shocks...Do I need new ones??? grebesjeep WK Grand Cherokee & XK Commander Forum 8 10-28-2009 11:33 PM
Rear tailgate metallica0682 ZJ Grand Cherokee Forum 4 09-03-2009 12:42 PM
Will a 98 ZJ Rear tailgate fit a 96 ZJ??? Matttv ZJ Grand Cherokee Forum 5 02-03-2009 09:00 PM
ZJ Rear Tailgate Swap 95JpZJ ZJ Grand Cherokee Forum 11 05-15-2008 04:39 PM
