rear sway bar question - JeepForum.com
post #1 of 9 Old 04-30-2013, 08:33 AM Thread Starter
Moparich
i will be ordering a front sway bar quick disconnect. my question is can i just remove the rear sway bar?
i currently have a 3" lift and 31" tires. drives fine and i dont want to create problems. its my wifes dd during the week about 5miles round trip and the weekend trail truck.
Moparich is offline
post #2 of 9 Old 04-30-2013, 08:41 AM
Myusername1674
Do you have a spacer lift? If so did you extend the retaining post in the rear? If not, then you may need to go do that.
I ditched my rear sway bar, im on a 2 inch bb w/ extended retaining posts in the rear.
I know Texaszj and I think Rat say not to take it off, as it doesn't limit flex very much. with it off ive heard you put more stress on the rear track bar
I'd not worry about it if I were you. You should be fine (i think).
Edit: dont worry about it as in leave it on.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #3 of 9 Old 04-30-2013, 09:06 AM
PolkaPower
Why would you remove a sway bar on the vehicle your wife drives? Just leave it on.
PolkaPower is offline
post #4 of 9 Old 04-30-2013, 09:21 AM
capcyclone
capcyclone's Avatar
Definitely don't remove the rear sway bar. Get the front sway bar disconnects - and take it out like that first. I think you'll be pleased with the flex that alone provides. For a DD, I wouldn't remove the rear sway bar.
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #5 of 9 Old 04-30-2013, 09:24 AM
ajmorell
ajmorell's Avatar
Leave it in.
ajmorell is offline
post #6 of 9 Old 04-30-2013, 11:26 AM Thread Starter
Moparich
thanks yall.
"Do you have a spacer lift? If so did you extend the retaining post in the rear? If not, then you may need to go do that.
I ditched my rear sway bar, im on a 2 inch bb w/ extended retaining posts in the rear."
i have a spring lift
Moparich is offline
post #7 of 9 Old 04-30-2013, 01:04 PM
Grand98
Am I understanding yall correctly? You can use front swaybar disconnects on the rear? I'm totally new to all this and trying to get some tips.
Grand98 is offline
post #8 of 9 Old 04-30-2013, 01:06 PM
tucsonzj
I'm debating ditching my rear sway. It's up to the person, know several people around here to don't have one on theirs and some due. If you're wondering, take it out and do a test drive. You'll feel a slight difference but it will handle most differently in emergency situations. So don't forget to account for that.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #9 of 9 Old 04-30-2013, 01:46 PM
WhiteOut
WhiteOut's Avatar
You can't use front disconnects on the rear. You don't need to disconnect or remove it and ultimately having the rear is a net benefit.
WhiteOut is offline
