Rear Springs/ Front BB vs BB w/ rear air bags - JeepForum.com
post #1 of 21 Old 01-02-2013, 01:42 AM Thread Starter
unabashedpraise
Did some searching and didn't feel satisfied with the results.
I'm lifting the Zj soon, ~1.5 -2", new shocks, possibly some new bushings and/or ca's (as needed). Will be towing a mix of: a small expedition trailer on vacations, loaded hitch cargo hauler, and maybe hauling some reasonable trailer fulls to the dump, say, 4-5 times a year tops. Will be adding a frame mounted tire carrier w/out new bumper.
As it sits the rear sags a bit more than I prefer when loaded with 2 adults and 2 kids heading to grandma's house for the weekend (no kitchen sink). With a smaller trailer loaded it sags a bit too (brush and wood not metal or rock). For giggles let's make the assumption that I am smart to know that it has nothing to do with excessive tongue weight or maxing the gross vehicle weight.
Unfortunately, I don't think a normal BB will do anything for the sag while under load. Do you suggest stiffer rear springs with front spacers? 1.5" up front, 2.25" pucks in the back? Or air bags with normal BB? (no oba, just a small 12v compressor) Maybe I'm missing something else? Some up country's all around with extra pucks in the back?
BTW, I'm not spending OME money. No way. My wife would...not be happy?
Thanks for the advice.
1998 Grand Cherokee Limited; 5.2 L, 249
Help: Rear left lock doesn't lock using power locks, but will unlock. Any ideas?
unabashedpraise is offline
post #2 of 21 Old 01-02-2013, 01:28 PM Thread Starter
unabashedpraise
I don't want anything that needs new steering components. I will save that if I want a larger lift later on down the road.
Also, I don't mind a raked stance, so long as it isn't substantial.
post #3 of 21 Old 01-02-2013, 05:14 PM
Y0ungGunZJ
front to rear swap. it will be just a tad taller then the pucks you want. if you think about it, it will cost you roughly the same. all the pucks = the cost of the new front springs, your buying shocks anyway, the only thing you might have to buy if you don't feel like straightening your rear track bar, is a front and rear track bar. which depending on the mileage of your ZJ, the bushings might be shot at this point it wouldn't hurt to have an aftermarket one.
you can get away with stock CAs and eventually replace them and get longer brake lines. just read through the write up, and post if you have any questions on it.
heres a good write up on it. theres no install guide or pictures in it.
http://mallcrawlin.com/forum/showthr...article-F-gt-R
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline
post #4 of 21 Old 01-02-2013, 06:14 PM
nicklopic
To fix that sagging you'd need rear springs, the Bb just raises the truck up but the actual spring rate of the springs remains unchanged. So you'll still sag even with the pucks.
Now if you want larger that 2 inches in the rear, you would have a rake normally and it should balance out when its all loaded up
Idk much about nor have experience with bags so I won't touch on that
You could replace the rear springs with something stiffer. I know you said no OME, but going with heavy duty rear springs and 2" pucks in the front would probably work well.
As for a cheaper option, you could replace the rear springs with upcountry coils. These were stiffer from the factory and netted 1" over normal ride height. (You should expect some sag though) Then use the 2" pucks.
That would probably leave you with a bit of a rake, nothing major, and when loaded up it would sag so much
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #5 of 21 Old 01-02-2013, 06:25 PM
redbeard144
1994 ZJ
jeep
why cant you use the old style air shocks,there cheap easy to install just put more air to lift the rear when you need to.they worked great back in the day to jack up the old hot rod.there about 70 buck a pair on ebay.
redbeard144 is offline
post #6 of 21 Old 01-02-2013, 07:10 PM Thread Starter
unabashedpraise
I am against the f<r swap, mainly due to the extra suspension issues involved and the higher lift. I want to keep the Jeep on a height that my kids and wife can get into without a step ladder. Once they are a few years older a higher lift may be in order.
Has anyone run any of these options on their own rigs?
post #7 of 21 Old 01-02-2013, 09:26 PM
nicklopic
I have the upcountry coils all around and Bb pucks. I do not tow though, I never see any sagging when I'm out driving with a full car, some tools, spare, my old wheels and assorted junk in the back. But I assume going would be a different story
98' ZJ 4.0
post #8 of 21 Old 01-02-2013, 10:48 PM
Mike97ZJ
Buy my Rancho 3" rear coils. They're stiffer than stock, and give about 2.5" of lift. They never rode better than when I was towing a small sized UHaul trailer or had a heavy as ***** old school air conditioner in the cargo area.
Mike97ZJ is offline
post #9 of 21 Old 01-02-2013, 11:28 PM Thread Starter
unabashedpraise
Anybody know if these 3" rear coils will require me to have a new rear trackbar? Would a relocation bracket work and be trustworthy?
post #10 of 21 Old 01-03-2013, 06:46 PM
nicklopic
I'm at about 3-3.5" in the rear
You need rear sway bar links, shocks, you really should get a track bar other wise the rear end will be kicked out to one side. If you get a bracket, you need to weld it in or it will break and that's not good
98' ZJ 4.0
post #11 of 21 Old 01-03-2013, 11:05 PM Thread Starter
unabashedpraise
Track bar and a bracket? Adjustable track bar only? Adj with bracket?
post #12 of 21 Old 01-03-2013, 11:17 PM
nicklopic
Just an adjustable track bar.
(IRO sells a fixed track bar for a 3.5" lift)
98' ZJ 4.0
post #13 of 21 Old 01-04-2013, 01:10 AM Thread Starter
unabashedpraise
OK. Suppose I purchase Mike's 1.75 front isolators and 3" rear spring coils. The rear coils supposedly would give me 2.5" of lift to rear, a solid 1.75" in the front. I would then need new rear links but not the front? IRO states that their links work for 3-7" of lift. Are there other links that would fit better? Is the net 2.5" considered a 3" lift?
Should I be able to leave the front alone after the isolators are installed?
In purchasing shocks, do I go for a 2" lift shock for the front and 3" lift for the rear?
This is why I really didn't want to do a bigger lift! Too many questions, and the money is adding up. I just want a small lift and for my rear coils to not droop!
post #14 of 21 Old 01-04-2013, 08:08 AM
PolkaPower
JKS sells front links from 0-3" of lift. I went with those.
PolkaPower is online now
post #15 of 21 Old 01-05-2013, 11:13 PM Thread Starter
unabashedpraise
You used JKS front links as rear links?
air bags , bb , sagging , springs , towing
