Rear speakers - JeepForum.com
post #1 of 5 Old 08-14-2011, 08:31 AM Thread Starter
cherokeen
Rear speakers
Anyone know how to install 6x9's into the rear?
I think i gotta take the door panels off in order to do so..
cherokeen is offline
post #2 of 5 Old 08-14-2011, 09:27 AM
ZJJay
ZJJay's Avatar
Yes, you'll have to take your door panels off. But I don't know if you'll be able to fit 6X9s, and if you could it might be a pain. I suggest getting a good pair of 6-1/2" or 6-3/4".
The Haynes Manual has instructions on removing the door panel. You'll probably need to replace some the plastic "Christmas tree" retainers. Do not buy them from the dealer. WAY too expensive. I'll try to look up the site and get you that info.
Jay
'96 ZJ, 4.0L, 42RE, NP242, stock D30 and D35-LS w/ 3.73, 4-1/2" lift, 32" BFG ATs, Magnaflow, JKS track bars and disconnects, spare tire carrier, Optima red top, ROLA roof rack, KC SlimLite driving lights, CB and Yaesu ham radios, GPS
ZJJay is offline
post #3 of 5 Old 08-14-2011, 09:30 AM
ZJJay
ZJJay's Avatar
Here's the site for any fasteners you might need: http://www.clipsandfasteners.com/Chr...iners_s/66.htm
Good luck.
ZJJay is offline
post #4 of 5 Old 08-14-2011, 10:25 AM Thread Starter
cherokeen
thanks a heap, real helpful i might just replace the infinity golds in the front with these 6x9s then, cheers again
post #5 of 5 Old 08-14-2011, 10:39 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
You will need to get speakers that are not too deep so as to not hit the window. Remove door panel. Use a door panel fastener remover and you won't break too many of the fasteners. There are screws to remove too. Get the old speaker out and then oval out the original speaker hole so the 6x9 will fit. Jigsaw with metal blade will handle that. Drill new mounting holes. Put a nice bead of silicon rubber on the door where the speaker meets it. Let it set up for a little while before mounting the speaker. Trim the plastic inside of the door panel where it sits against the speaker.
Or build a bezel and mount it to the outside of the door panel. Then you can mount any size speaker you want with any depth. Plus it will sound better mounted on a piece of wood. Like this, the bolts look ugly but you could purdy it up with different hardware
HighLonesome is offline
door panel removal , speaker replacements
front/rear speakers the same? fern30 ZJ Grand Cherokee Forum 7 09-08-2010 01:21 PM
direct fit, decent rear door speakers in a 97 ZJ? RDB_ZJ ZJ Grand Cherokee Forum 12 08-14-2010 11:27 PM
rattling rear door speakers vonericsen ZJ Grand Cherokee Forum 7 01-07-2010 08:58 PM
No sound from rear speakers with aftermarket deck 05greeny WK Grand Cherokee & XK Commander Forum 3 12-11-2009 07:40 PM
99 Jeep GC rear door speakers? replacement robraby ZJ Grand Cherokee Forum 5 11-11-2009 08:50 PM
