Rear side window\vent leaking? - JeepForum.com
post #1 of 11 Old 11-03-2008, 12:20 PM Thread Starter
vosevichs
2000 WJ: I'm getting closer to my leak. My spare tire well has been filling up with water. Couldn't see how water was getting in there. After i washed the jeep this weekend the carpet in the rear driver side, right between the fuel filler hump and the back corner was soaked. Then running into the tire well. HAHA. So is the vent behind the rear side window real or decoration. How is the side window attached? Going to try to remove the interior pieces and hopefully a little silicone will seal things up.
Scott Vosevich
vosevichs is offline
post #2 of 11 Old 11-03-2008, 05:36 PM
elmer_fud
I think the vents are real.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #3 of 11 Old 11-03-2008, 06:00 PM
Okiejeep07
Have the same problem. I removed the rear interior panels off, no luck. Removed and reinstalled and sealed luggage rack and still no fix. I finally gave up and just learned to live with it. I'm leaning towards the rear vents, just haven't had the patients to remove them yet. Frustrating.
Okiejeep07 is offline
post #4 of 11 Old 11-03-2008, 06:18 PM
CMARJEEP
CMARJEEP's Avatar
The vents are real. I think they are clipped on. But behind them there are little rubber flaps. Also, the vents on the sides of the tail lights are real. If you take off the tail lights you can see the vents. Let me see if I can find how you remove the vents behind the window.
Edit: Here you go.
CMARJEEP is offline
post #5 of 11 Old 11-04-2008, 06:25 AM Thread Starter
vosevichs
Thanks alot guys, Going to have to get in there this week and check it out. I'll let you know if I find anything Oke
Scott Vosevich
post #6 of 11 Old 11-07-2008, 12:05 PM
mikelmco
Did you find anything? How did the vent removals go?
mikelmco is offline
post #7 of 11 Old 04-29-2009, 07:50 PM
srode
2008 XK Commander
I have the same leak in a 1999 grand - can't figure it out - anyone solve this one yet?
2008 XK Commander Limited 4.7 Quadra Trak II
1999 Jeep Grand Cherokee 4x4 Quadra Drive 4.7 L 163,000 miles(sold)
2004 GMC SLT Crew Cab 4x4 Duramax Diesel
1969 Camaro Pace Car
1969 Camaro Hard top
91 Cherokee - sold at 188,000 miles, still runing great at 250k last report
srode is offline
post #8 of 11 Old 03-24-2011, 12:17 AM
mcight
i think my leak is coming from the same place, checking tommorow to make sure
mcight is offline
post #9 of 11 Old 07-10-2012, 10:46 PM
boomer1717
same problem, 99 GC, my leak is coming from the rubber seal around the rear window, then comes down behind the panel (right by the latch to the window) all the way to the floor and ultimately drains in the spare tire well. just tried removing the entire rubber seal, resealed it with silicon and will see how it works tomorrow.....if you're having this problem, I'd recommend removing the back door panel and spraying the back with a hose and see if that is where it's coming from
boomer1717 is offline
post #10 of 11 Old 07-06-2013, 01:41 AM
RussOne
That D-Pillar is the source of my leak. There is a drain hose that runs from it. When it rains, water leaks in from the D-Pillar but not through the hose. I myself, will attempt to remove this pillar to see how this leak is really materializing.
RussOne is offline
post #11 of 11 Old 06-18-2015, 06:39 AM
lbwhetstone944
My 02 wj leaks the same place, but once I had a friend pour a bottle of water along the top of my driver-side back window. 90% of the water came straight into the jeep. I'm not sure what kind of weather-stripping goes along those windows, but basically there must be none!!. I rode around with a strip of black duct tape over that gap for the longest time (obviously looked terrible). Took it off a few weeks ago, had a Hail of a storm last night, woke up with my interior soaking. Can someone please tell me what weather-stripping goes there andthe best way to get to it?
lbwhetstone944 is offline
Side rear window mounting clips needed for '02 WJ. Jerry Bransford ZJ Grand Cherokee Forum 2 01-16-2010 01:26 PM
Rear side window size on an 07 WK BigSensFan WK Grand Cherokee & XK Commander Forum 1 03-12-2008 11:28 AM
rear axle near side seal leaking Russ7567 ZJ Grand Cherokee Forum 9 07-03-2007 11:45 AM
Rear vent window conversion quitecoolguy ZJ Grand Cherokee Forum 4 10-12-2006 01:42 PM
A hah! Found rear passenger A/C vent leaking water.... HokieZ ZJ Grand Cherokee Forum 4 06-28-2005 05:15 PM
