Rear shock problem - JeepForum.com
post #1 of 3 Old 07-05-2006, 12:38 PM Thread Starter
madcabbie
madcabbie's Avatar
Rear shock problem
Ok ever sence my lift, i can hear a sound when i hit a bump. The rear right shock sounds like there is play in the mounts.
For example, take your let hand and hold it about an inch above your right fist, Move your right fist up quickly, and you hear a smack when they connect AND THEN both hands move together. But if you take a large eraser and place it between your palm and fist, as soon as you move your right hand, the left lifts up with it. Understand?
Im just trying to best explain what the sound is. Or seem like it. I'v wrenched on the shocks as hard as i can to no avail. There not moving, no shimmy or shake. So any ideas would be great?
99 WJ
4.0l|Westin Side Steps|Safari Bar|Pro Comp Explorer Lights| Rustys Catback|31in Yokahama Geolander AT II's|KOR 2.5in BB|V8 UC springs for a total of 3.5in Lift|Rubicon Shocks|OME SS|
Everytime Someone calls a Jeep, an SUV, GOD Kills a kitten.
madcabbie is offline
post #2 of 3 Old 07-05-2006, 12:44 PM
sand zj
sand zj's Avatar
You may be missing a bushing that goes inside the rubber at the ends of your shocks. You wouldn't feel the slack when moving by hand but may notice when driving.
Dan
If you don't get stuck, keep trying!
'96 ZJ 7" LA, 318, 231, 8.8 (welded), d30 (LockRight), 4.10's, 33x13.5x16 TSL's, no interior...
sand zj is offline
post #3 of 3 Old 07-05-2006, 05:03 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Check your sway bar ends where they hook up to the links going to the frame. I have a rattle in mine and it is from the sway bar.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
Rear Shock Replacement - New Problem mpj680 ZJ Grand Cherokee Forum 1 01-01-2010 12:13 PM
2004 Gr Cherokee Shock Problem cultcab ZJ Grand Cherokee Forum 4 04-06-2009 08:08 PM
WK05 Laredo shock problem. mllr WK Grand Cherokee & XK Commander Forum 2 09-28-2008 05:33 PM
rear shock mounting problem! lakailimited06 ZJ Grand Cherokee Forum 0 06-17-2008 07:20 PM
left rear shock problem driabyor ZJ Grand Cherokee Forum 4 11-08-2004 05:21 PM
