Rear seat won't fold down - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rear seat won't fold down
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and CJeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 04-24-2009, 01:35 PM   #1
RochesterSS
I've got a '96 Grand Cherokee and I've gotta fill the back up with wood so I want to fold the back seats down so the whole trunk and back seat area is one flat space. I can't find any release mechanism to get the back seats to fold down though. Help would greatly be appreciated, thanks.
RochesterSS is offline   Reply With Quote Quick reply to this message
Unread 04-24-2009, 01:48 PM   #2
tommylee84
1994 ZJ
On the passenger and dirver side if you life the seat up on the outer corners there should be a little black tab in the vertical position. Push back on it while rocking the seat alittle and it should unlock and fold forward.
Tom
1994 ZJ 5.2,46RH,242
tommylee84 is offline   Reply With Quote Quick reply to this message
Unread 04-24-2009, 02:20 PM   #3
JG_Canuck
You also have to lift the seat bottoms forward first.
IIRC on a ZJ you also have to remove the headrests.
Canadian Jeep Club Member Forty-Two
JG_Canuck is online now   Reply With Quote Quick reply to this message
Unread 04-24-2009, 11:50 PM   #4
Tiggerrrrr
weird.. my 95 has a lever on the door side of the seat backs at the bottom of the seat.
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline   Reply With Quote Quick reply to this message
Unread 04-25-2009, 02:31 AM   #5
sandman
mine too, must be a 96-98 thing.
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote Quick reply to this message
Unread 04-25-2009, 04:01 AM   #6
Mickey_D
Yup, my 95 has the removable headrests (that go into the seat bottoms at the back once they're folded up) and on the door side at the hinge there's a black curved handle that looks like a piece of trim for the hinge itself. Pull that forward and up and then grab the top of the seat back and pull it forward and down.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is offline   Reply With Quote Quick reply to this message
Unread 02-10-2015, 04:36 PM   #7
rarmstrong0125
1994 XJ Cherokee
I know this is an old post but I have a 'new' problem. I have ZJ 95 style rear seat in my XJ. The passenger side backrest will not go down. it seems that the black plastic pull handle is stripped or broken. It's sad and funny but I just installed these in my XJ so they are from a JY but in good shape. The worked the entire time until I was done with my 2-day project to fit these seats and now it won't go down. Ironic because that is why I put the split seats in the first place.
Any ideas how to fix this?
If it aint broke, make it BETTER!
rarmstrong0125 is offline   Reply With Quote Quick reply to this message
