Quantcast Rear Rotor Removal help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rear Rotor Removal help
Old 04-06-2008, 10:25 AM   #1
CarFanatic
I cant seem to get these rotors to come off!! IS there a trick to removing them?
CarFanatic is offline   Reply With Quote
Old 04-06-2008, 10:31 AM   #2
mathieus98zj
I had problems getting mine off as well, they were rusted on a bit. I just gave them some loving taps.
mathieus98zj is offline   Reply With Quote
Old 04-06-2008, 10:32 AM   #3
alexo1us
make sure the parking brake is clear and as mentioned before a big hammer
08 Overland crd
5.9 Wrecked 12 24 07
My New Love Stolen /07/07
01 Grand limited 4.7V8/QD
SFN Silver on Grey
alexo1us is offline   Reply With Quote
Old 04-06-2008, 09:09 PM   #4
CarFanatic
ok, I gotta go get a bigger hammer! They will side off over the parking brake pads right?
Old 04-06-2008, 09:40 PM   #5
Reswob
As long as the parking brake isn't set.
'98 ZJ Laredo 5.2L Selec-Trac ~ Rock crawler on the outside, luxo-cruiser on the inside
3.5" IRO lift // 31" Cooper STT's // D44a Aussie Locker // NP242 swap // KOR Tow Shackles
'08 Kawasaki Ninja 250R ~ Daily Driver, 50 mpg Speed Demon
#27. Shirts get dirty. Underwear gets dirty. Pants? Pants never get dirty, and you can wear them forever.
Reswob is offline   Reply With Quote
Old 04-07-2008, 08:14 AM   #6
CarFanatic
ok, they just must be really rusted on. I will have to try a bigger hammer.
Old 04-07-2008, 08:23 AM   #7
mrese
A LONG pry bar with a good hit of the hammer 180 deg from where the pry bar is.
Mark
'99 WJ Limited 4.7 K&N Filter CB 3" IRO
255.70.18 JK Bridgestones
Rear Addco
280K
mrese is offline   Reply With Quote
Old 04-07-2008, 08:38 AM   #8
CarFanatic
well theres only one area you can hit the back of the rotor, because of the dust sheild. I tried a pry bar in between the rotor and caliper braket bolt holes, nothin! I"m gonna try a heaver hammer this weekend.
Old 04-07-2008, 08:58 AM   #9
NYC_ZJ
Jeep for LIFE!!
NYC_ZJ's Avatar
Don't hit the back of the rotor. you might damage the rotor surface. I used a hammer and hit the front of the rotor where the wheel touches the brake rotor...in between the wheels studs. It will loosen alto of rust then maybe a pry bar too.
BTW: Fill out your signature so we know what type of Jeep your dealing with.
1996 ZJ - 4.0 w/ 159,000 miles
3" Rusty's springs, Black Diamond Shocks, JKS Quicker Disco's, IRO Adj. Lower Control Arms, OME SS, KOR's adj. TB conv. kit, JKS Rear Track Bar,
31x10.5x15 BFG KO's on Soft 8's
ZJs Only club member #58
NYC_ZJ is offline   Reply With Quote
Old 04-07-2008, 09:06 AM   #10
CarFanatic
I dont care if it damages the rotor, I have a new one. I just need to get the old one off! Its an 04 WJ
Old 04-07-2008, 09:38 AM   #11
QuadraTokn
1930 WJ
If that is the case, simply hit the rotor harder with a mini sledge. Since you dont have to be careful, just keep whacking it.
Also when i replaced mine on friday, I sprayed PB blaster on the front by the lug nuts, and when the rotor came off i noticed the PB had penetrated itself all the way around to the middle part of the rotor. So im sure that helped.
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 04-07-2008, 09:43 AM   #12
QuadraTokn
1930 WJ
plenty of tips here: http://jeepforum.com/forum/showthread.php?t=542621
Tread Lightly
Pictures
Old 04-07-2008, 07:29 PM   #13
zjay
If the rotor has broken loose from the axle and feels 'springy' when you try to pull it off and it snaps back on, then the park brake shoes are holding them on. A rust ridge builds up on the edge of the braking surface area and keeps the rotor from sliding off over the shoes. Eventually you'll pull the park brake shoe retaining pins through the backing plate and that aint good.
So IF THEY ARE LOOSE from the axle already and just don't want to slide off more than a few MM, you need to un-adjust them through the access slot in back of the backing plate. Kinda tricky, and if you turn the star wheel one way and it locks the rotor from spinning, that must be tightening, so go the other way.
If thats whats holding them, they'll just about fall off after the unadjustment.
If it's just rusted to the axle, yeah give it hell. I've broken rotors to pieces trying to break them loose, they can be tight.
zjay is offline   Reply With Quote
Old 04-08-2008, 08:23 AM   #14
CarFanatic
ya, its not the pads holding it, its definatly rusted on there.
Old 04-08-2008, 08:39 AM   #15
98zjteen
apply heat to the area between the studs where it is rusted on. Once its heated , use a good hammer and hit all around. it will come off, but be careful, its hot.
98zjteen is offline   Reply With Quote
Glock Forum
