-   -   Rear Rotor Removal help (http://www.jeepforum.com/forum/f13/rear-rotor-removal-help-542599/)
CarFanatic 04-06-2008 09:25 AM
I cant seem to get these rotors to come off!! IS there a trick to removing them?
mathieus98zj 04-06-2008 09:31 AM
I had problems getting mine off as well, they were rusted on a bit. I just gave them some loving taps.
alexo1us 04-06-2008 09:32 AM
make sure the parking brake is clear and as mentioned before a big hammer
CarFanatic 04-06-2008 08:09 PM
ok, I gotta go get a bigger hammer! They will side off over the parking brake pads right?
Reswob 04-06-2008 08:40 PM
As long as the parking brake isn't set.
CarFanatic 04-07-2008 07:14 AM
ok, they just must be really rusted on. I will have to try a bigger hammer.
mrese 04-07-2008 07:23 AM
A LONG pry bar with a good hit of the hammer 180 deg from where the pry bar is.
CarFanatic 04-07-2008 07:38 AM
well theres only one area you can hit the back of the rotor, because of the dust sheild. I tried a pry bar in between the rotor and caliper braket bolt holes, nothin! I"m gonna try a heaver hammer this weekend.
NYC_ZJ 04-07-2008 07:58 AM
Don't hit the back of the rotor. you might damage the rotor surface. I used a hammer and hit the front of the rotor where the wheel touches the brake rotor...in between the wheels studs. It will loosen alto of rust then maybe a pry bar too.
BTW: Fill out your signature so we know what type of Jeep your dealing with.:rtft:
CarFanatic 04-07-2008 08:06 AM
I dont care if it damages the rotor, I have a new one. I just need to get the old one off! Its an 04 WJ
QuadraTokn 04-07-2008 08:38 AM
If that is the case, simply hit the rotor harder with a mini sledge. Since you dont have to be careful, just keep whacking it.
Also when i replaced mine on friday, I sprayed PB blaster on the front by the lug nuts, and when the rotor came off i noticed the PB had penetrated itself all the way around to the middle part of the rotor. So im sure that helped.
QuadraTokn 04-07-2008 08:43 AM
plenty of tips here: http://jeepforum.com/forum/showthread.php?t=542621
zjay 04-07-2008 06:29 PM
If the rotor has broken loose from the axle and feels 'springy' when you try to pull it off and it snaps back on, then the park brake shoes are holding them on. A rust ridge builds up on the edge of the braking surface area and keeps the rotor from sliding off over the shoes. Eventually you'll pull the park brake shoe retaining pins through the backing plate and that aint good.
So IF THEY ARE LOOSE from the axle already and just don't want to slide off more than a few MM, you need to un-adjust them through the access slot in back of the backing plate. Kinda tricky, and if you turn the star wheel one way and it locks the rotor from spinning, that must be tightening, so go the other way.
If thats whats holding them, they'll just about fall off after the unadjustment.
If it's just rusted to the axle, yeah give it hell. I've broken rotors to pieces trying to break them loose, they can be tight.
CarFanatic 04-08-2008 07:23 AM
ya, its not the pads holding it, its definatly rusted on there.
98zjteen 04-08-2008 07:39 AM
apply heat to the area between the studs where it is rusted on. Once its heated , use a good hammer and hit all around. it will come off, but be careful, its hot.
The time now is 11:10 AM.
