Rear rotor removal - JeepForum.com
post #1 of 9 Old 10-13-2006, 01:11 PM Thread Starter
mmgrand
Rear rotor removal
Well I decided to replace the leaking rear axel seal and possibly the bearing if needed. But I can't get the rear rotor to budge. I've tried beating, prying, soaking with penetrating oil and also tried using a 1/4 bolt and nut thru the caliper hole to break it free.. I've loosened the E brake using the star wheel. Anyone ever have this problem? It's a 1999 Grand Cherokee. Any suggestions other than rolling it off a cliff? Thanks for looking.
mmgrand is offline
post #2 of 9 Old 10-13-2006, 01:22 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
A bigger hammer...
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 9 Old 10-13-2006, 04:45 PM
nierace
nierace's Avatar
2003 WJ
Originally Posted by ArloGuthroJeep
A bigger hammer...
I usually use a mallet even though you aren't going to reuse the rotor, otherwise wear a good pair of goggles.
Rotate it around and keep whacking it as you rotate, then try tugging at it straight on after a few rotations...
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #4 of 9 Old 10-13-2006, 05:40 PM
///BHRpowered
///BHRpowered's Avatar
get a rubber mallet, relieve some stress. You probably have more then the rotor, hence the rotor will submit to your commands.
"A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter
"But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL"
Admin -
///BHRpowered is offline
post #5 of 9 Old 10-15-2006, 12:05 PM
jmaley
Stuck Rotor
I had the same problem, I used two prybars carfully wedged behind the rotor and kept rotating and carfully beating on the rotor hat until it broke loose. It looked like the center hole for the axle flange had rusted to the rotor hat. I took a Dremil tool and snading drum to the inside radius and cleaned up the edge, since then no problem getting the rotor off.
Hope this helps
jmaley is offline
post #6 of 9 Old 10-15-2006, 11:36 PM
StealthPossum
Not sure about the 1999, but my 2002 was a PITA to get off until I completely released the pressure on the parking brake pads inside the rotor. Involved taking out the center console and part of the carpet in the back to release the cable at the parking brake lever and Y junction behind it....ridiculous I know. However, they both just slide right off after that. I also tried the hammer, prybar, harsh language, star adjuster before doing this (and I wasn't going to replace the rotor anyway; so I wasn't nice...still didn't work until Idid the above procedure.) FWIW, good luck.
StealthPossum is offline
post #7 of 9 Old 10-19-2006, 07:43 PM Thread Starter
mmgrand
Sorry for not responding sooner, it's been a hecktic week. Thanks for all the ideas. If the weather stays decent I'll give it another go this weekend and let you know how it turns out. Thanks again.
mmgrand is offline
post #8 of 9 Old 10-23-2006, 06:36 AM
sharky777
Or you can just heat up the rotor bewtwen the lugs with a blow torch and occsionally hit with a no so big hammer and they will come right off. Remember you don't want to melt anything just heat it up to loosen it.
sharky777 is offline
post #9 of 9 Old 10-24-2006, 04:41 PM
KrazysJeep
I had the same problem with my '01 when replacing the bad seal- heated it, used WD-40, big hammer. Eventually a gear puller did the trick and the rear rotor is now slightly warped (can barely tell when stopping from high speeds of 60mph+).
BTW, I had to replace the bearing. If the 99 is the same as an 01, there is a press-on ring that needs to get cut off to get to the seal and bearing. I took it to a machine shop and they had to cut the bearing due to it being so close to the ring.
KrazysJeep is offline
Rear Rotor Removal help CarFanatic ZJ Grand Cherokee Forum 25 05-07-2013 05:17 PM
Front/Rear Brake Rotor Removal AngryDog ZJ Grand Cherokee Forum 9 10-29-2009 08:39 AM
Rear rotor removal on a 99 Grand Cherokee dirtyjeepdc ZJ Grand Cherokee Forum 5 05-08-2009 12:08 PM
Mom's WJ Rotor Removal Bloodbath ZJ Grand Cherokee Forum 19 07-06-2007 12:16 PM
Rear Rotor Removal / Emergency Brake problems wvresq ZJ Grand Cherokee Forum 4 09-10-2005 10:32 PM
