Rear pinion bearing replacment cost? - JeepForum.com
post #1 of 5 Old 08-24-2007, 06:05 PM Thread Starter
jhrljeep
97 zj with dana 44 making grinding noise at rear right. Sounds like a brake pad is worn but it's not the brake. Grinding at about 5mph and up in drive and neutral. Through research I think it is either the pinion bearing or the carrier bearing. Does this sound right and if so what is the typical time required by a garage to do the fix? Thanks!!
jhrljeep is offline
post #2 of 5 Old 08-25-2007, 12:18 AM
PR1AWRet
2002 KJ Liberty
I'm thinking a wheel bearing instead. A pinion bearing (front) will whine on acceleration and the rear will whine on deceleration. Unless the diff is empty or had a HEAVY shock load, pinion and carrier bearings are pretty indestructible.
$25 for the wheel bearing and about $150-200 for removal and replacement (2 hours).
PR1AWRet is offline
post #3 of 5 Old 08-25-2007, 12:58 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
a friend of mine had has carrier bearings replaced at a shop here in town, they cost him $450....but that shop suck total @$$...they overcharge for everything.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #4 of 5 Old 08-25-2007, 06:51 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Andy, you're not far off - I seem to remember it costing me between $3-400 for the job. Can't remember the exact cost, it was a couple years ago.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #5 of 5 Old 08-25-2007, 08:40 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Find a place that does regears and go there instead, probably cheaper. Since changing the pinion bearing is basically a regear. You'll need to pull out the carrier and replace the pinion bearing and at that point you should change the carrier bearings as well. Just to be safe a pattern should be run on the gears afterword to make sure it is still acceptable.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 09:14 AM
99 WJ pinion bearing mjs691 ZJ Grand Cherokee Forum 0 12-31-2009 05:28 PM
Pinion Bearing question and Rear Main neoncrazy101 ZJ Grand Cherokee Forum 2 10-22-2009 08:59 AM
Pinion Bearing - Rear randyszj94 ZJ Grand Cherokee Forum 8 11-13-2007 06:14 PM
Reasonable price for rear pinion bearing install speed01 ZJ Grand Cherokee Forum 7 11-05-2005 01:35 AM
