rear Oxygen Sensor Wiring questions - Page 3 - JeepForum.com
post #31 of 32 Old 11-12-2013, 08:09 AM Thread Starter
roadcruzer
No Start- Stalled when AC button pressed?
I will check it but why do you think when I pressed the AC button it just up and died. Tried again this morning and still no start. I hear of a fuse blowing for some people that give a no start condition and need to be replaced. Do you know which fuse ( or relay?) this is i need to check. Do you think this Immediate stall when button pressed on AC have blown my PCU? Seems funny it will not even fire now just by pressing AC button.
roadcruzer is offline
post #32 of 32 Old 11-12-2013, 06:08 PM
ZeeJay1997
when you press the AC button, the pcm sends a ground to the relay which, in turn, sends voltage to the clutch. the ac relay coil is on the same circuit with asd and fuel pump relay, so you probably have fuse 18 in the PDC blown. the most obvious cause for the fuse blowing would be a shorted coil in the AC relay, but i've never seen that happen.
ZeeJay1997 is offline
