Quantcast Rear Main seal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rear Main seal
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 01-04-2008, 06:56 AM   #1
hrjaw
Rear Main seal
can anyone tell me how difficult it is to replace the rear main seal on my 99 4.0 grand cherokee, or point me in the right direction for a write up?
Thanks,
Roger
"Walking from your house, to your Jeep, to the bar, is not an adventure"
hrjaw is offline   Reply With Quote
Old 01-04-2008, 07:00 AM   #2
micifus
Original GC'er
micifus's Avatar
Its a two piece seal. You need to remove the oil pan, starter, trasmission cover. There is then two bolts, the bottom of the seal drops out with when you take the two bolts off. You then need to push the top seal out and through. Put the new seal in the same why you took the old one out.
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
1987 Suzuki LT230S Quadsport
1996 Artic Cat ZR580 EFI
2005 Honda TRX450R
"For every one thing I fix two things break"
micifus is offline   Reply With Quote
Old 01-04-2008, 07:02 AM   #3
hrjaw
That is what I was hoping for (two piece seal). thanks much!
Old 01-04-2008, 08:01 AM   #4
99grand4.0
1997 XJ Cherokee
there is also a main cap girdle that bolts across the bottom of all of the main caps that you have to remove. be sure to torque everything back to spec and be careful not to damage the rear bearing when you have the cap off.
SOLD 1999 Wj 4.0
Auto/Truck/Jeep parts and accessories/installation custom work, fabrication and paint/body work
Customandclassicauto@gmail.com
www.customandclassicauto.com
586-524-9321
99grand4.0 is offline   Reply With Quote
Old 01-04-2008, 08:03 AM   #5
hrjaw
thank you. I will keep all this in mind. would you figure this would be approx. a 6 hour job or so?
Old 01-04-2008, 08:05 AM   #6
greasefingers
1994 ZJ
This is the one for my 4.0L engine 1994
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Old 01-04-2008, 08:06 AM   #7
hrjaw
should I do anything else while I am in there?
Old 01-04-2008, 08:20 AM   #8
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Change the oil filter to go with your fresh oil.
Also, be sure to use black RTV on all 4 corners of the oil pan and also a few dabs on each side of the rear main.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 01-04-2008, 08:20 AM   #9
hrjaw
Glock Forum
