Rear Lamp Failure HELP!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rear Lamp Failure HELP!!
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 04-08-2008, 10:40 AM   #1
rckymtnlegacy
My buddy and I have been working on his 1997 Grand Cherokee. On his display it says "rear Lamp Failure" but we cannot figure it out. We thought it was the wiring for the trailer but its not. What could it be?
rckymtnlegacy is offline   Reply With Quote Quick reply to this message
Unread 04-08-2008, 10:43 AM   #2
mathieus98zj
Maybe a bulb in the third break light.?
mathieus98zj is offline   Reply With Quote Quick reply to this message
Unread 04-08-2008, 10:48 AM   #3
QuadraTokn
1930 WJ
common problem. typical fixes: a bulb in the two tail lights and the 3rd upper brake light assembly may be a different type/brand, make sure all bulbs in upper brake light are working.
LIKE US ON FACEBOOK: Valhalla Fabrication
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline   Reply With Quote Quick reply to this message
Unread 04-08-2008, 10:52 AM   #4
IronManVa
I AM IRON MAN
IronManVa's Avatar
I've read somewhere that the license plate bulbs can cause this???
2004 Overland 4" KOR/IRO Long Arms
2004 Rubicon 6.5" RK X-Factor LA on 35" KM2s 488s Tom Woods & plenty of BTF Armor ORO U-Turn system
1995 Jeep Orvis 4.0 3" Rancho
www.jeeporvis.com ... www.jeepartist.com ... www.kmaoffroad.org Virginia Beach ... www.obxbreakers.comOff season Jeeper Deals
IronManVa is offline   Reply With Quote Quick reply to this message
Unread 04-08-2008, 11:32 AM   #5
alivenkickin28
after you do that make sure that in the rear tail lights your side marker lights are not blown....if you have a blown bulb go ahead and replace them all at once so that they are all new and u wont have to worry about them for another 10 years or so
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
[url]http://s221.photobucket.com/albums/dd197/alivenkickin28/[/url]
alivenkickin28 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2008, 03:22 PM   #6
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
What everyone else has said, PLUS:
That third brake light may look OK with 2 bulbs working, but there are three bulbs in there (usually).
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline   Reply With Quote Quick reply to this message
Unread 04-08-2008, 06:19 PM   #7
alivenkickin28
93 and 94 had 2 bulbs and 95 and up had 3 bulbs....but also they may look okay but could be the incorrect bulb....so check them to make sure they're the right wattage bulb as well
Unread 04-08-2008, 07:46 PM   #8
SJZ
SJZ's Avatar
Three bulbs in my '94, hence the "usually" in my prior post.
-Steve
Unread 04-08-2008, 09:23 PM   #9
alivenkickin28
yeah u musta got a late 94....which had some of the newer changes in it...
Unread 04-09-2008, 01:26 AM   #10
mrobers
About a mont ago I had the same problem. All bulbs were ok. Turned out that I had a blown fuse (nr. 5 behind the passenger-kick-panel) which feeds +12V to the Lights Out Module. The LOM sends +12V back to the VIC indicating status OK. When no +12V, it says 'Rear Lamp Failure'.
Try checking the fuse
1976-er Dodge W200 5.2 V8 (offroad-hobby)
1978-er Mercury Marquis Colony Park 6.6 V8
1985-er Suzuki SJ410 (offroad-hobby)
1989-er Corvette C4 Convertible 5.7i V8
1997-er Jeep Grand Cherokee 5.9 V8
1998-er Alfa 166 3.0 V6 Sportronic
mrobers is offline   Reply With Quote Quick reply to this message
Unread 04-09-2008, 08:40 AM   #11
nashmd454
good call if the bulbs are ok.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
[URL]http://photobucket.com/albums/v639/nashmd454[/URL]
[url]http://groups.jeepforum.com/The_Dark_Side[/url]
nashmd454 is offline   Reply With Quote Quick reply to this message
Unread 04-10-2008, 12:59 AM   #12
98ZJ_USMC
Sometimes, "when" it comes on can help track down the offending or dead bulb. On my first go around, it would show up as soon as I depressed the brakes after start up. I found out about the three bulb hi-mount light that way. Sure as *****, the two outboard bulbs were dead. Started back up, pushed the brake pedal..........fixed?.....fixed!
...nope.....came back on after about 20 secs. While doing the slow burn, i pulled the two rear tailight clusters out again and finally found the marker lamps. Driverside was blown. Replaced it. Problem solved and sanity restored!!
Bulbs existing in the rear of a 98 ZJ:
Running/Stop Light 1 each side
Turn signal 1 each side
Back-up light 1 each side
Side marker light 1 each side inserted right next
to the running/stop light (194)
Hi-mount stop light 3 total in one cluster (922)
License plate light 2 total
Great thread! Now, I replace my Coolant Level Sensor this weekend and the VIC will rest quietly!
BTW, if your battery is getting old, REPLACE IT!!! I have found that the ZJ electronics are very sensitive to voltage drop. My alarm got finicky for a while and the VIC read some false indications. I don't use the alarm but, it's aggravating when it goes off (duh). New battery, problem solved! Previous owner disconneted the horn because of it. Now, my horn(s) work!
98 ZJ 5.2 Auto with "one [COLOR="DarkOrange"][SIZE="5"]million[/SIZE][/COLOR]" miles on it. Camoclad exterior means you never have to wax it! The journey continues......Jeep On, baby!
98ZJ_USMC is offline   Reply With Quote Quick reply to this message
Unread 04-11-2008, 02:18 PM   #13
Hootsawn
A bulb is burnt out in the tail lights or third brake light.
'96 ZJ Limited V8 NP249 255/70R16 - SOLD
'00 WJ Laredo V8 NP247
265/75R16 Firestone M/T on stock rims,
Kevin's 2.5" BB, Skyjacker Hydros,
Addco Swaybars F&R
Hootsawn is offline   Reply With Quote Quick reply to this message
Unread 04-11-2008, 02:24 PM   #14
CrazyDrivinJoe
1994 ZJ
OK i have the answer I have the same problem if you wired the trailer wiring into the original wires and maybe cut the wires at all then ther is ur answer it relays that u have a failure because it is some how shorting out or something. I had no problems wiht my trailer hitch wiring until it some how went crazy and shorted a relay so it got tosed and before that i knew it wa s relay i replaced the light harness and just spliced it in there and it has acted up since but the brake lights and parking lights work fine... if it bothers u disconnect the box they are junk reasons y they were replaced
94 ZJ I6 Second 4.0 as of 226k Aftermarket Intake, Flowmaster 40 series, Rear Discs
05 Kawasaki Ninja ZX-6R 636 just ridiculously fast
96 Nissan Altima 5 speed stock and probably keepin it that way aka the beater or commuter car who wouldnt buy it for a grand with how gas is
CrazyDrivinJoe is offline   Reply With Quote Quick reply to this message
Unread 05-11-2013, 05:03 AM   #15
jhadire
Chek your neutral safety switch
jhadire is offline   Reply With Quote Quick reply to this message
