rear lamp failure - JeepForum.com
post #1 of 22 Old 03-20-2008, 10:28 PM Thread Starter
jhram318
rear lamp failure
on my 98 grand limited my on board diagnostics (spelling) says "REAR LAMP FAILURE" but all my lights are working (back up,tail, stop, and turn signal) so if there all working why does it say this all the time is there a light that i'm over looking or what PLEASE HELP this is getting on my nerves so bad i'm thinking about unpluging the whole thing
jhram318 is offline
post #2 of 22 Old 03-20-2008, 10:40 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You're missing a bulb still. Or you had a bulb go out and didn't replace it with the correct bulb. In the third (middle) brake light there are three (I think) bulbs in there. Make sure all are lit up and the proper bulb. That is most likely your culpret.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 22 Old 03-20-2008, 10:56 PM
jeeptorino68
1992 XJ Cherokee
check for a cruddy connection or one of the third brake lights to be out, there are three and from what i have been reading if one goes, it sets off the signal also there is some kind of black box behind the spare tire or something
check over on NAGCA
search around for it there are a few threads
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #4 of 22 Old 03-20-2008, 11:01 PM Thread Starter
jhram318
i didn't think about the third brake light haveing three in ti that may be the problem right the thanks ill check it tommorow and see
jhram318 is offline
post #5 of 22 Old 03-21-2008, 03:19 AM
mrobers
I just solved my Rear Lamp Failure message (see this thread)
Test fuse number 5 in the distribution center (passenger side foot well). If it is shot, replace and your message is gone. Assuming all lights are in working order (including the 3 bulbs in the third brake light)
mrobers is offline
post #6 of 22 Old 01-08-2009, 09:28 PM
rallyjeep_11
i have the same problem, but it only does it every now and then. like today i parked it and it said it, then i got back in and when i started it it didnt say rear lamp failure.. idk whats goin on..
If you were wondering, everything i say is stupid.
98 zj red. /2"bb /5.2l/rough country hydro 8000's/ rough country SS/ hella 500's /flowmaster muffler/ 3.5" tip, highflo cat, gear alloys and 255/70r16 sport kings
rallyjeep_11 is offline
post #7 of 22 Old 01-09-2009, 05:54 PM
compcrasher86
and if by chance you need to access the sensor module that detects if lights are out, its in a little pull panel between the spare tire stock location and the liftgate. nice little tan box in there is your taillamp failure sensor.
yeah but try the fuse thing first lol
Matt
compcrasher86 is offline
post #8 of 22 Old 08-15-2009, 09:46 PM
Smokey1r
Rear Lamp Failure
I recently had the same issue with a 97 GC , but i did have some lamps that were out and the 3rd brake light assembly that had incorrect bulbs in it, also i had to repair the VIC's bad solder joints, soon as all them issues were solved the message went away.... just curious does the failure message appear right after you press on the brakes or shows up before?.
Smokey1r is offline
post #9 of 22 Old 08-15-2009, 10:23 PM
driabyor
driabyor's Avatar
1994 ZJ
3rd brake can have 2 or 3 bulbs..... mine has 2 bulbs
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #10 of 22 Old 08-15-2009, 10:28 PM
97DCZJ
one of your bulbs are about to go out. I had the same problem a few months back.
one by one, replace a bulb, see if the notice goes away, if not, move onto another bulb.
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #11 of 22 Old 08-16-2009, 12:43 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
early(fixed glass) had 2, later has 3.
ratmonkey is offline
post #12 of 22 Old 08-16-2009, 12:47 AM
taythegibs
well i have the same problem....i was wondering why my 3rd brake light only had one small bulb in the middle
taythegibs is offline
post #13 of 22 Old 08-17-2009, 07:13 PM
Smokey1r
With my situation the 3rd brake light lamps i discovered were one of the original ge922 bulbs that had a massive amount of electroplating on the interior of the bulb, basically was at the end of its service life, and the other 2 were newer T906 bulbs, all 3 were working at the time of the vic stating rear lamp failure, but it only showed the error when the brake pedel was pressed, did this before the rear left and right lamps and one front marker lamp were replaced and after. I replaced all 3 of the 3rd brank lamps with T922's and all is well with the vic once again.
Smokey1r is offline
post #14 of 22 Old 08-17-2009, 07:37 PM
moparrr07
you didnt by chance test the trailer harness with a test light did you, i have seen that blow a modual before
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #15 of 22 Old 09-17-2009, 04:51 PM
Bannonjr
As I was searching for a problem, I came across this thread...related to my problem.
I had a problem with my reverse lights not working, so I went through the harness, found it all corroded, rebuilt it and all is fine...minus the reverse lights which i moved to 55watters on the rear roof.
My brake lights worked, running lights and turn signals.
Now as for the post above, I just went to plug in my trailer, 7pin-4 adapter....oops, no more running lights.
My brake lights work, turn signals, just no rear lights.
I checked fuse 5 and all is well.
Any ideas? I'm trying to go out, but it's getting dark and driving without rear lights is not something I want to do, especially with a trailer...
Someone help?
Your Friendly Canadian Amsoil Dealer!
Red Jeep Club #151
Canadian Jeeps Club Member #25
Bannonjr is offline
Rear Lamp Failure JesseOR ZJ Grand Cherokee Forum 7 11-24-2009 10:11 AM
Rear Lamp Failure JrMechanic ZJ Grand Cherokee Forum 23 02-27-2009 12:38 PM
Rear Lamp Failure!!! FortCollinsZJ ZJ Grand Cherokee Forum 36 07-24-2007 09:30 AM
rear lamp failure again gregs887 ZJ Grand Cherokee Forum 7 01-12-2007 11:03 PM
Rear Lamp Failure ddoffroad ZJ Grand Cherokee Forum 2 12-25-2002 05:46 PM
