Rear lamp failure - JeepForum.com
post #1 of 8 Old 07-04-2006, 11:33 AM Thread Starter
lowdwn
Rear lamp failure
So this is a good one for you----that is driving me insane!!!!!
one day out of the blue, the message center starts blinkin at me "rear lamp failure". So I check all bulbs, and all bulbs are just fine-- So after searching on here, I found that if must still be a bulb somewhere- to make a long story short, every freakin bulb back there is now new-- including marker lights, tail lights, backup lights, signal... the 3 hatch lights, and the license plate marker lights.... and yes, they are the correct bulb number-types........ Driving me mad!! everytime I get in, start the Jeep up, press the brake pedal, I just want to scream!!!
is there anything else I can try?--
Another thing that has just started randomly started, is that when I start the jeep, the message center resets the the date/time etc..... and the strangest thing is that it only happens when the jeep has been sitting in the sun for awhile... NEVER does it in the morning... .. But anyway-- I'm sure that problem is battery related..
lowdwn is offline
post #2 of 8 Old 07-04-2006, 12:08 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
new battery or old battery?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 8 Old 07-04-2006, 09:24 PM
ponsta
i got the same problem. just changed out the battery because i needed a new one. all my lights work. i just ignore it.
'04 Freedom Edition Silver and Black Stock
'98 5.9 Deep Slate Stock for now
ponsta is offline
post #4 of 8 Old 07-05-2006, 08:51 AM
wmchurch
You replaced the bulbs but you didn't mention if all the lights work. I have a side marker out in my left rear, and even after replacement (2 times) and cleaning the socket it still won't light. One day I'll pull it out and really check it, but I was tired that day. :P
1994 Jeep Grand Cherokee Limited
122kmi
5.2L all stock baby...
wmchurch is offline
post #5 of 8 Old 07-05-2006, 10:12 AM Thread Starter
lowdwn
old battery still... and all the back bulbs light up-- I triple checked.. YES all them light up lol....
lowdwn is offline
post #6 of 8 Old 07-05-2006, 05:44 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
u gotum tired battery. get new.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #7 of 8 Old 07-06-2006, 06:32 AM
zjeepin
zjeepin's Avatar
I have the same problem battery is fine. I just ignore it. I think it has something to do with the way I spliced in my trailer lights package, cause thats when it started.
97 ZJ Chop Top-Buggy 5.2L V8, 249 T-Case
5" Lift, JKS Front and Rear Adj. Trackbars, RE Twin Tube Shocks, RE T-Case Drop, Cut Fenders, Chop Top, Half Doors.
33"x13"x16" Super Swamper TSLs on Black Steelies
Custom Rack, 4 Roof Lights, Roof Back-up Lights
zjeepin is offline
post #8 of 8 Old 07-06-2006, 10:57 AM
Decipticon
Could be that you have a bizarro VIC like I do. I get about every message that thing can throw at me. Only reliable ones anymore are the doors, washer fluid, and oil level. Everything else fires at will.
Jesus is coming. Look busy.
Decipticon is offline
Rear Lamp Failure HELP!! rckymtnlegacy ZJ Grand Cherokee Forum 15 05-11-2013 09:19 AM
Rear lamp failure chadgtr ZJ Grand Cherokee Forum 8 10-30-2006 06:29 PM
Rear Lamp Failure eprovenzano ZJ Grand Cherokee Forum 8 10-01-2006 08:48 PM
New Rear Lamp Failure cs_18m ZJ Grand Cherokee Forum 35 06-01-2005 12:14 PM
rear lamp failure delby ZJ Grand Cherokee Forum 8 04-17-2005 01:01 PM
