Rear lamp failure - JeepForum.com
post #1 of 8 Old 03-27-2013, 01:28 PM Thread Starter
thumper450
Rear lamp failure
93 grand wagoneer info center in front of the shifter flashes and reads rear lamp failure but all the bulbs and lights are working. Is this just gremlins?
thumper450 is offline
post #2 of 8 Old 03-27-2013, 01:46 PM
Gungnir
mine does the same thing, i noticed that my socks havent been disapering from my dryer latley so i just figured the sock gremlins have relocated.
the check engine light and coolant sensor bad warning on my ZJ arnt on. I think my jeep might be broken :(
Gungnir is offline
post #3 of 8 Old 03-27-2013, 02:37 PM Thread Starter
thumper450
Amen, that's what I was thinking if that's the only problem I got no worries. But then again it's a zj. LOL
post #4 of 8 Old 03-27-2013, 06:26 PM
KoreaZJ
1994 ZJ
Did you check the center stop lamp bulbs? There's two. Could also be wrong bulb types.
To help isolate whether it's an actual lamp problem or a VIC problem (bad solder joints)... bypass the LOM (Lamp Outage Module).
Locate LOM behind small removable panel near lower-left corner of liftgate.
Bypass LOM by unplugging both connectors, then plugging them together.
If you still get the message, likely a VIC problem. If not, check bulbs again.
KoreaZJ is offline
post #5 of 8 Old 03-27-2013, 06:29 PM
misfit77
wrong bulbs. Stupid jeep uses wierd sizes. Ordered mine from amazon. local stores do not carry
misfit77 is offline
post #6 of 8 Old 03-28-2013, 06:59 AM
ejschultz
ejschultz's Avatar
Your VIC probably needs to be resoldered. It's an easy job and there are some walkthroughs on here. If you search for them, you'll find them.
ejschultz is offline
post #7 of 8 Old 03-28-2013, 05:20 PM
durango-bob
2006 WK
Check the small bulbs on the sides of the tail lights. There should be one per side.
durango-bob is offline
post #8 of 8 Old 03-28-2013, 06:44 PM Thread Starter
thumper450
Thanks, I've checked all the bulbs and they all work properly
