Rear lamp failure - Page 2 - JeepForum.com
post #16 of 22 Old 07-22-2012, 06:01 AM Thread Starter
Proph2010
1994 ZJ
Thanks Korea, you've quite a help on all of my electrical issues!!
Proph2010 is offline
post #17 of 22 Old 07-22-2012, 06:30 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Isn't there some kind of little module used on trailer brake hookups for jeeps? Like an isolator or something?
Originally Posted by HighLonesome
coralman is offline
post #18 of 22 Old 07-22-2012, 06:47 AM
KoreaZJ
1994 ZJ
The factory tow package uses an additional 3 relays (stop,left turn,right turn), circuit breaker, and wiring that isolate the trailer lamps from the main circuits. Bundled behind a rear side panel.
Without the factory package, aftermarket kits including "converters" (3 relays in a box) and wiring perform the same functions.
Either way the additional relays/wiring keep the trailer lamps load isolated so it doesn't mess with the LOM, stock relays, etc.
KoreaZJ is offline
post #19 of 22 Old 07-22-2012, 10:04 AM
Billyjoebob007
Originally Posted by Proph2010 View Post
Every time after ignition that I depress the brake pedal I get the rear lamp failure... All the bulbs are good. Any known fail points here guys. This is the only thing that I don't know what it is, can anyone identify this wire, it's packaging with the right(passenger side) tail light wire harness.
LoL, i have the exact same issue, but mine didnt start to do it until after i had hauled a trailer .
Billyjoebob007 is offline
post #20 of 22 Old 07-22-2012, 10:09 AM
Billyjoebob007
Originally Posted by Rog95zj View Post
I also get the rear lamp failure. I see ppl on here talk about soldering the VIC. How do you go about checking it and fixing it. Is there a Wright up on here and maybe your wire may have been some one trying to put tow wire in.
You have to remove the vic and open it up and with a magnifying glass look at each solder point for any cracking or solder separation and if you find any re solder those.
post #21 of 22 Old 07-22-2012, 08:34 PM
Rog95zj
Thanks
Rog95zj is offline
post #22 of 22 Old 06-03-2013, 07:53 PM
shortys_95zj
question on the factory tow package wiring
i have the factory tow package wiring in my 95 zj and the only thing that works in my trailer plug is the parking lights. i took apart the passenger side of the inside quarter panel in the cargo area and started testing the wires with a test light. all the relays work minus the one that the circuit breaker goes to, could the circuit breaker be my problem? if so where do i find one of these, my local auto parts stores don't carry 10 amps just 20 and higher.
shortys_95zj is offline
