-   -   Rear lamp failure (http://www.jeepforum.com/forum/f13/rear-lamp-failure-1395505/)
Proph2010 07-20-2012 02:36 PM
Rear lamp failure
1 Attachment(s)
Every time after ignition that I depress the brake pedal I get the rear lamp failure... All the bulbs are good. Any known fail points here guys. This is the only thing that I don't know what it is, can anyone identify this wire, it's packaging with the right(passenger side) tail light wire harness.
ilive4cars0122 07-20-2012 02:52 PM
That is a tough picture to tell what that is. Are you positive all the bulbs are working sometimes one of the third brake light bulbs or front corner lamps/turn signals will trigger the message as well. Other than that the VIC could need to be re-soldered.
Proph2010 07-20-2012 03:00 PM
Yes I'm sure all the bulbs are good and working well; Vic works perfect with everything else but maybe that signal solder is loose or disconnected; I have half the dash out al ready ill check those connections too.
Front bulbs will trigger rear lamp failure?! That's seems stupid, there's not a front lamp failure alarm?
JS97ZJ 07-20-2012 03:04 PM
The bulbs all need to be the same #s in pairs.
ilive4cars0122 07-20-2012 03:07 PM
Actually you know what I do think I was wrong about the front bulbs being able to cause the message. I was probably thinking about quick turn signal clicking means it's out. Anyways my VIC looked fine as well until I soldered it and the message went away.
Proph2010 07-20-2012 03:08 PM
I'll check the vic
KoreaZJ 07-20-2012 10:32 PM
Where does that single wire go?
That white plasic gadget in your pic is an "inline tap splice" which is not stock. You have an extra wire spliced into your stock harness, likely into the Stop Lamp wire. The tap splice pierces the insulation without cutting either wire.
http://images.lowes.com/product/conv...50683277lg.jpg
Wires are inserted, then the metal "E" shaped tang is compressed down to pierce the insulation and make the electrical connection. The plastic arm then clips over the top to cover/insulate the metal tang.
http://www.radioparts.com.au/images/43577093.jpg
This type of splice does not work well for very long in an exposed environment. With the insulation pierced, the wire conductors are now exposed. Wires will corrode causing intermittent connections, then eventual broken wires.
Either you have an intermittent connection within the splice... or the extra unknown wire is causing the Lights Out Module to report a "Rear Lamp Failure" to the VIC.
The extra wire routes down and could have been an add on for trailer lights. Might be something similarly fishy on the drivers side.
Open the plastic splice clip, open the splice, push the metal tang back up, remove the splice, remove the extra wire, make sure your original wire is still intact... see if the VIC message still appears when you hit the brakes.
Rog95zj 07-20-2012 10:40 PM
I also get the rear lamp failure. I see ppl on here talk about soldering the VIC. How do you go about checking it and fixing it. Is there a Wright up on here and maybe your wire may have been some one trying to put tow wire in.
coralman 07-21-2012 01:33 AM
http://www.jeepforum.com/forum/f13/c...-fixed-175207/
cody_love 07-21-2012 05:47 AM
check your towing control box if you got the towing sit up from the factory its located in the emergency fuel door release i replaces mind and it fixed it
Proph2010 07-21-2012 06:31 AM
Thank you, yeah I wondered if that was stock or not; I can't find the other end lol but it's just on the right(passenger side) that wire if it isn't stock will be my guess on the vic, because everything looks good on the back of the VIC.
MaintMech 07-21-2012 06:39 AM
And this'll help also:
http://www.jeepforum.com/forum/f13/c...moval-1228233/
Proph2010 07-21-2012 02:26 PM
1 Attachment(s)
Found the other end of our splice, you were right, must of had a fault with the trailer brake light hook up so he tapped directly... Doesn't seem to be my VIC problem since its a direct connection or would you electrical gurus say the probably exactly the problem?
Proph2010 07-21-2012 02:29 PM
1 Attachment(s)
Edit: it said the picture didn't post and I can't delete post from my phone.
KoreaZJ 07-21-2012 10:01 PM
That black box is your Lamp Outage Module. When a rear lamp problem is detected for at least 1/2 second, it sends a signal to Pin#23 on the VIC which triggers the Rear Lamp Failure message.
Try removing both connectors from the LOM, plug them together, see if message comes back. If it does, then you might have an open circuit in your VIC... perhaps a fractured solder joint as others suggested.
If the message goes away with the LOM bypassed, either the LOM is bad or there's an actual wiring/lamp problem. Try disconnecting your mystery wire.
Even if problem is repaired/stops, need to cycle the ignition key to clear the message.
The time now is 12:43 PM.
