Rear hatch - JeepForum.com
post #1 of 3 Old 11-10-2003, 01:45 AM Thread Starter
Mikey2
Rear hatch
I was wondering if anyone knew how to open the hatch from the inside of the vehicle. Since my hatch is not opening. It lock and unlocks fine with the remote can hear it and with the key can feel it. But you pull the handle and it gives a little pop like it going to open but then doesn't . Anyone have any ideas
Mikey2 is offline
post #2 of 3 Old 11-10-2003, 02:41 AM
Interloper
Interloper's Avatar
Try having someone push from inside as you pull the latch outside. If you get it open, lube the latch mechanism real good with WD-40 or equiv. My hatch was seized up on mine cuz the prev. owner never used it. Water likes to lay down there, mine was a real PITA at first but no probs in the 5+ years since. HTH.
1995 ZJ Limited. 4.0L
"nobody cares what's underneath," ...Dieter Zetsche
Interloper is offline
post #3 of 3 Old 11-10-2003, 06:14 AM
Swamp Boy
Swamp Boy's Avatar
The best way to do it is to take the cover off the inside of the door..
First remove the floor cross piece .. THen take off the door skin.. THen you will see a mechanism inside the door...
There is a short rod with an adjustable clip.. Pop the rod out adjust the clip and put it back together... IT is very common ON Grand Cherokees.. And not easy to do without the door open..
BUt it is possible... I did mine..
Do a search on rear hatch you should find others giving the same advice..
Sounds wierd now but it will make sence when you see the inside of the door mechanism..
Good luck..
Carl
Just another soccer moms Grocery getter....
Swamp Boy is offline
need help rear hatch 96 gc BQuinn ZJ Grand Cherokee Forum 12 06-01-2008 11:42 AM
rear hatch quickfix ZJ Grand Cherokee Forum 8 10-26-2007 08:39 PM
rear hatch times ZJ Grand Cherokee Forum 5 09-27-2006 07:22 AM
93 rear hatch cubesk2k2 ZJ Grand Cherokee Forum 6 08-08-2006 09:34 PM
rear hatch EYPUFF ZJ Grand Cherokee Forum 2 10-28-2004 07:41 AM
