Rear Hatch - JeepForum.com
post #1 of 15 Old 06-01-2007, 09:13 AM Thread Starter
augnmike
Rear Hatch
My rear hatch is sticking or won't open now almost every time I try to use it. I tried searching the forum but the search function won't work. Is there a posted fix for the hatch problem?
augnmike is offline
post #2 of 15 Old 06-01-2007, 10:06 AM
ajmorell
ajmorell's Avatar
In order to fix it, you will need to get it open so that you can remove the back panel. Sometimes applying some pressure above the latch helps. Once you remove the back panel, you will see a long screw looking arm that is connected to a latch. The part which holds that in place just probably needs to be adjusted. Sounds much more complex that it is. If you take it apart I am sure you will see what I am talking about.
ajmorell is offline
post #3 of 15 Old 06-01-2007, 11:16 AM
UUJ1
What kind of vehicle do you drive and what year?... Yugo, Chevette, Festiva, Focus, Jeep...? It helps to know sometimes.
UUJ1 is offline
post #4 of 15 Old 06-01-2007, 02:01 PM Thread Starter
augnmike
Sorry it's a '98 JGC. The hatch will open on about every fifth pull on it so I know I can get it to open.
augnmike is offline
post #5 of 15 Old 06-01-2007, 02:44 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Does it work better when you push on the hatch first (as if to close it) then pull the release handle? If so some cargo may be binding it or the stops (at the lower corners) may be adjusted too tight and binding it.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #6 of 15 Old 06-01-2007, 03:04 PM
madcabbie
madcabbie's Avatar
Sounds like the problem I had...just needed to adjust the pull cables that attached to the handel...next time you get it open..pop off the panel and adjust them...
99 WJ
4.0l|Westin Side Steps|Safari Bar|Pro Comp Explorer Lights| Rustys Catback|31in Yokahama Geolander AT II's|KOR 2.5in BB|V8 UC springs for a total of 3.5in Lift|Rubicon Shocks|OME SS|
Everytime Someone calls a Jeep, an SUV, GOD Kills a kitten.
madcabbie is offline
post #7 of 15 Old 06-01-2007, 05:32 PM
nashmd454
nashmd454's Avatar
maybe the locking bracket that it locks too has shifted and needs adjusting. Mine was loose so I adjusted it and noticed that is was too tight and I had to push on the tailgate and pull the release lever to get it to open...so then I adjusted it again and all is well....
in case you don't know how to adjust...look under the rear bumper and you will find 2 nuts (no pun intended) and loosen them.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #8 of 15 Old 06-01-2007, 06:34 PM Thread Starter
augnmike
Yeah pushing on it doesn't seem to make a difference at all. Nothing inside pushing against it either. I am sure it's the adjustment that a couple of you have mentioned already. I was hoping for a better description of what I am gonna see inside when take the panel off. I am not mechanically inclined so that is why I am being so anal about a description of the rod and the adjustments I will need to make. If I tackle it I will try and take some pics for the next poor bast@&d that has to do this.
augnmike is offline
post #9 of 15 Old 06-01-2007, 08:45 PM
nashmd454
nashmd454's Avatar
excuse us for trying to help...maybe a little more description would be better. There is thread on rear wipers not working...listen first ok...it will show you how the rear hatch comes off...reason why I say this is because there are 2 screws you do not see in the carpeted section on the rear hatch. I have been on here for awhile and have never seen anyone mention this particular problem you are experiencing...if so I do not recall it...but the best way I know how to get inside the hatch is through that write up someone did awhile ago. Sorry we weren't more helpful.
post #10 of 15 Old 06-01-2007, 10:38 PM Thread Starter
augnmike
Nash, not sure what you picked up in my last post but I was in no way upset or thinking that anything so far was lacking. I was trying to say that I was hoping for an in depth explanation because I am a knuckle head when it come to this stuff. I have always received great info on this site especially since I am new to this kind of thing. I was only saying that it is unfortunate that nobody has pics of the job but that's the way it goes. Again, sorry for the misunderstanding and thanks to all of you for the advice. If I do decide to try and fix it I will take some pics.
augnmike is offline
post #11 of 15 Old 06-02-2007, 09:09 AM
cyberbrain
I had a similar problem where the hatch locks itself. I had to break the interior plastic on the hatch to get to the lock mech. then I could slide the locking assembly over by hand.
Ha, you can't get there.....hrm, watch me.
2008 Wrangler Unlimited X. 4dr, 4x4, 3.8 V6, 3.73 D44 LSD.
93 Grand Cherokee Laredo. SOLD. Sad to see it go.
cyberbrain is offline
post #12 of 15 Old 06-02-2007, 09:14 AM
gunthagunth
gunthagunth's Avatar
Remove the interior plastic of the liftgate and then spray all the linkages and latches liberally with Wd40. Pull the latch a few times and spray it again. Test it out and after it works fine follow up with white lithium spray to keep everything lubricated. I never get around to using the lithium grease so I have to WD40 every 6 months. I get the exact same problem and it is caused by some light binding in the linkage, which puts stress on them and causing them to flex a bit. Which is just enough to keep the latch from popping. When people put pressure on the plastic around the latch they are helping keep the linkage straight and keep it tight as the linkage moves to release the latch.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #13 of 15 Old 06-02-2007, 09:36 AM
nashmd454
nashmd454's Avatar
I did not interpret anything you said as negative...I was being more apologetic for not having the info you were looking for. I would still try loosening the nuts from under the rear bumper...that will loosen the bracket and maybe eliminate the sticking...and if it is the cable and such then I still recommend researching a thread on here about working on the rear wiper and you should find pics on how to remove the hatch cover pieces and also the 2 screws you do not see that are mounted inside the carpeted aresa.
post #14 of 15 Old 06-02-2007, 10:08 AM Thread Starter
augnmike
Good idea on the wiper suggestion there may be some pics for that which is the same place I need to get into anyway.
augnmike is offline
post #15 of 15 Old 06-02-2007, 10:56 AM
nashmd454
nashmd454's Avatar
hope that helps you out...that is how I learned to take my back cover off or I would have broken it with those 2 hidden screws. Another idea is to spend a few dollars and get a Hayne's manual...great source of help...that and a Chilton's. I have both. I hear the best (spendy) is a FSM (Factory service manual).
Doug
rear hatch quickfix ZJ Grand Cherokee Forum 8 10-26-2007 09:39 PM
rear hatch times ZJ Grand Cherokee Forum 5 09-27-2006 08:22 AM
93 rear hatch cubesk2k2 ZJ Grand Cherokee Forum 6 08-08-2006 10:34 PM
rear hatch EYPUFF ZJ Grand Cherokee Forum 2 10-28-2004 08:41 AM
Rear hatch Mikey2 ZJ Grand Cherokee Forum 2 11-10-2003 07:14 AM
