Rear feels like it is bottoming out! - JeepForum.com
post #1 of 4 Old 12-20-2001, 10:43 PM Thread Starter
95jeepL
I have a 3" lift with 31 1/2" tires, when I hit even the smallest of dips, my rear hits hard and it feels like I bottom out. I've got fairly new shocks and I know that they aren't faulty. What could my problem be and how do I fix it?
95jeepL is offline
post #2 of 4 Old 12-22-2001, 04:16 PM
Kess
i think the 31.5s are a wee too big for the zj wheel well, and that may be why it feels like it is bottoming out, rubbage
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline
post #3 of 4 Old 12-22-2001, 07:31 PM
turk
I just installed a teraflex 3Z (3") lift and I experience, on occasion, a similar problem. I have yet to go to larger tire size (currently 235/75 r15). I still have stock control arms on my vehicle and I was told by teraflex that that may be the problem. I would doubt you have stock arms with a 3" lift and 31" rubbers. However, pending what kinda of arms you have, they may influence the performance. Make sure all of the hardware on your control arms are secure. Check you spring retainers and make sure the springs are seated properly.
Just a few suggestions, I am far from an expert.
It doesn't matter what you drive as long as it is a JEEP.
98 JGC Laredo 4.0, 3" lift, Rustys adjustable UCA's & LCA's, Custom K&N intake, high flow exhaust, Jet chip Stage 2 and 32x11.5 BFG TA's
turk is offline
post #4 of 4 Old 12-24-2001, 02:59 PM
mattvw65
I have installed a teraflex 3Z (3") lift and i to had the problem did you install your shocks up side down? take them off cycle them {up and down} then install right side up this fixed my problem hope this helps
Matt
96 zj
73 vw thing
cool quote
Put your seat belt on I want to try something!
mattvw65 is offline
WJ feels squirrelly Sandbox ZJ Grand Cherokee Forum 3 06-03-2009 06:10 PM
Shop says "Axle is Bottoming Out" causing my popping/chafing noise??? Flyusaf2002 ZJ Grand Cherokee Forum 12 01-05-2009 06:30 AM
Rear end feels bouncy. Could it be my UC Springs are just old? bjl95mustang ZJ Grand Cherokee Forum 4 10-02-2008 09:17 PM
Back end bottoming out Sandbagger66 ZJ Grand Cherokee Forum 7 08-14-2007 11:27 PM
shocks bottoming out after 2.125 BB install a70eliminator ZJ Grand Cherokee Forum 19 03-07-2007 10:12 AM
