Rear end whine - JeepForum.com
post #1 of 8 Old 04-24-2005, 06:57 PM Thread Starter
ddombrowski
Rear end whine
Ok guys,
I'm not too active on this board, so I really appreciate anyone that helps someone like me that doesn't contribute much. My mom has a 99 JGC, 2WD, 4.0L. It has 80,000 miles on it.
Lately, my mother has been saying that a whirring noise is coming from the back of the Jeep. I realize that "my car is making a noise" is the hardest thing to diagnose over the internet, so I'll do my best to describe it.
Its definitely a noise that increases in pitch with velocity. You can only hear it when there is a torque on the driveshaft (i.e., when coasting, it goes away). Its loudest while accelerating (I've only heard it once, and I wasn't driving, otherwise I would have put various loads on it to see how it changed). If you throw the tranny in neutral, it goes away completely, so its not engine related.
The noise doesn't decrease in pitch once you shift, so I think its only dependant upon the angular velocity of the driveshaft, and not the transmission.
I change the diff fluid at 60,000 miles with 75W90 Synthetic Gear Oil. At the time, the old oil looked old, but nothing out of place. I checked the rear diff to see if perhaps the oil had leaked out, but the area was bone dry. I did not have time to climb under the car and actually check the diff oil level.
At 78,000 miles, I flushed and filled the trans and put a new trans filter on. After that I drove the car for about 3 days with no incident before I went back to school.
My guesses are either that there is something wrong with the differential, wheel bearings, halfshafts, or mabye the U-joints (I don't even know if the car has U-joints).
Oh, and the diff is just a regular open diff, no LSD.
Anyone that has any idea of what this noise might be, your experience is greatly appreciated. If I can give you any more information, just ask! Thanks alot guys!
ddombrowski is offline
post #2 of 8 Old 04-24-2005, 08:37 PM
tehpwnt
It sounds like the rear end might be failing. Mine was doing the same thing and I had to have it rebuilt.
'97 Grand Cherokee Laredo 4.0 I6
K&N FIPK Gen. 2
JBA Cat-Back Exhaust
Hypertech 93 Octane Tuning
Rancho 2" Coil Spring Lift System
ProComp ES3000 Shocks
ProComp ES2000 Steering Stabilizer
Daystar Front/Rear Sway Bar Bushings
Optima Yellow Top Battery
American Racing Chrome Pythons (15x8)
BFG All Terrain T/As 235/75/15
Sylvania SilverStar Headlamps/Foglamps --- TRADED!
'03 Ford SVT Focus <----The new ride
tehpwnt is offline
post #3 of 8 Old 04-24-2005, 10:02 PM
PDshooter
CK the diff, take the cover off, and have a look see? Pinion bearing can make that sound too......Let us know what you find out.
96 GC 117K 4.0
Sele-Trac
Retired guard 20yrs
MOS 63H 11B 43E
PDshooter is offline
post #4 of 8 Old 04-25-2005, 08:23 AM
PumaZJ
also check the carrier bearings for play. theyre notorious for going out.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #5 of 8 Old 04-25-2005, 08:27 AM
Tim750r
Hi all
If the carrier bearings are out, is this a shim/preload adjustment, or does that mean they're shot and need replacement?
Tim750r is offline
post #6 of 8 Old 04-25-2005, 08:37 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I'd replace them.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 8 Old 04-25-2005, 09:26 AM
Tim750r
If you replace the carrier bearings, do you have to do the whole ring-pinion preload alignment thing?
Are there any particular symptoms of the carrier bearings going? Mine's making a sort of chuff-chuff but can't decide if its wheel bearings, carrier bearings or LSD clutches...
Its done 103K, so probably all 3!
Tim750r is offline
post #8 of 8 Old 04-27-2005, 09:39 AM Thread Starter
ddombrowski
Thanks everyone
Thanks for everyone's suggestions. I'll be taking a look at those bearings the next time I'm under the car. I think if anything I'll be going with a rebuild kit and just have it installed since I won't be around (I go to school pretty far away from where my parents live) to do it.
I think its pretty sad that differential bearings would go after 80,000 miles. My volvo has 190,000 on it, and my BMW has 145,000. I guess anything can fail at any time, but this is the first I've seen of something like this.
Thanks again for the help guys.
97 ZJ rear end whine warrior23 ZJ Grand Cherokee Forum 1 08-20-2009 10:33 PM
Rear end whine Jeep Brian WK Grand Cherokee & XK Commander Forum 2 01-28-2007 12:47 PM
Help Please- Rear End Whine oregon2 ZJ Grand Cherokee Forum 1 09-17-2006 08:06 PM
ZJ Rear End Whine at 40+ MPH FWombat ZJ Grand Cherokee Forum 3 07-13-2005 06:45 PM
rear end whine? 93_zj ZJ Grand Cherokee Forum 6 12-15-2004 01:13 PM
