rear end whine? - JeepForum.com
post #1 of 7 Old 12-14-2004, 12:32 PM Thread Starter
93_zj
rear end whine?
I have a 93 Grand Cherokee with the AW4 automatic and np 242 transfer case,ever since i bought this vehicle with 197,000 miles on it,there has been a whining/scraping noise coming from the rear end it's really noticable once you get up to 20 mph and all the way up,once it hits about 67 mph the car starts vibrating,i changed the tires to brand new ones just barely and it didn't make hardly any difference at all,does anyone know what could be wrong with this,it now has 207,000 miles
93_zj is offline
post #2 of 7 Old 12-14-2004, 12:44 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Check the, rear brakes (93 has drum rear) and differential to try and isolate where the noise is from. Do you know which diff you have? It usually dana 35c but dana 44a was on ZJs with factory towing package.
Check http://www.jeepforum.com/forum/showthread.php?t=82474
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #3 of 7 Old 12-14-2004, 12:44 PM
Meerkat
Well, if it was brakes, they would have worn down a long time ago. Bad wheel bearings wouldn't last 10000 miles either. So, it must be in the differential. Most likely caused by the ring and pinion gears not meshing properly. They are probably close enough to not shatter, but off enough to cause a whining sound. When is the last time you checked the fluid level in the differential?
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #4 of 7 Old 12-14-2004, 08:32 PM Thread Starter
93_zj
it was full about a month ago
93_zj is offline
post #5 of 7 Old 12-14-2004, 09:38 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Maybe it's late but, the thread title got me to look.
Gears baby, definitely the gears.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 7 Old 12-15-2004, 01:01 PM
Eds97ZJ
My guess is I'll be having this problem somtime too. I checked the oil in the rear and when it came out of the hole it looked like metal flake paint. Why did they use aluminum against steel in the rear? IDIOTS!!
What fluid would you guys suggest I use to try and counter act this?
1997 Jeep Grand Cherokee LMTD Loaded 5.2 V8 Q-Trac 4X4
Eds97ZJ is offline
post #7 of 7 Old 12-15-2004, 01:13 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Any gear oil will do (75w-90 or 80w-90). Just do not use synthetics because you need the rear diff rebuilt.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
97 ZJ rear end whine warrior23 ZJ Grand Cherokee Forum 1 08-20-2009 10:33 PM
Rear end whine Jeep Brian WK Grand Cherokee & XK Commander Forum 2 01-28-2007 12:47 PM
Help Please- Rear End Whine oregon2 ZJ Grand Cherokee Forum 1 09-17-2006 08:06 PM
ZJ Rear End Whine at 40+ MPH FWombat ZJ Grand Cherokee Forum 3 07-13-2005 06:45 PM
Rear end whine ddombrowski ZJ Grand Cherokee Forum 7 04-27-2005 09:39 AM
