Rear End Rumble - JeepForum.com
post #1 of 5 Old 02-19-2007, 03:56 PM Thread Starter
barrowjeep
Rear End Rumble
Hi,
Just bought my first Grand Cherokee 1996 this week. After reading all the possible faults i decided to commit to buy, and guess what.
After picking the car up, we had done about 50 miles and noticed a rumbling from the rear end, the noise is the same noise at all speeds more or less, obviously a quicker rumble at faster speeds. When i go round a left hand bend at any speed the rumble disappears, straight or turning right, the rumble is there. When i got in the back with my wife driving, the sound seems to be coming from the left of centre on the back end.
The vehicle has been laid up for a few months, possibly because of this problem, it has just passed a yearly MOT here in the UK which involves testing the brakes on a rolling road, obviously the garage didn't pick up any problem.
Any help would be appreciated, i am hoping (wishing) it could just be a wheel bearing, or could it be the dreaded rear axle.
regards,
Graham
barrowjeep is offline
post #2 of 5 Old 02-19-2007, 06:08 PM
GreenDean
GreenDean's Avatar
Pull the rear diff cover off and take a look at the gears.
GreenDean is offline
post #3 of 5 Old 02-19-2007, 07:11 PM
bdwg
u-joint
check the one closest to the diff. that's the one that goes mine the fastest...
bdwg is offline
post #4 of 5 Old 02-19-2007, 08:40 PM
02_limited
Mine was making a "rrrr rrrr rrrr" noise. Luckily it was still under warranty and dealer replaced with new rear axle assembly kit. Then later on, I was hearing a squeaking/squealing noise in the rear. I thought it was brake/rotors but it was a bent right rear axle shaft. Replaced under warranty too.
02 WJ Limited 4.7 Quadradrive
02_limited is offline
post #5 of 5 Old 02-20-2007, 05:36 PM Thread Starter
barrowjeep
Thank's guys. I shall drop the diff case, after checking the fluid level. What should i be looking for in regards to the gears/bearings etc; ?????????
momentary rumble strip-like vibrations, 5.9 volksman ZJ Grand Cherokee Forum 9 12-17-2009 10:03 PM
Rumble, vibration in rear end?? Gerald K4NHN ZJ Grand Cherokee Forum 2 12-02-2007 11:40 AM
Rumble/vibration at highway speeds Little Black ZJ ZJ Grand Cherokee Forum 4 09-09-2007 05:18 PM
Rumble from drivetrain? DTom ZJ Grand Cherokee Forum 2 12-03-2005 06:24 PM
Vibration (Rumble) only under acceleration Deanwa ZJ Grand Cherokee Forum 4 08-24-2004 09:58 PM
