Rear end questions - Page 3 - JeepForum.com
post #31 of 39 Old 11-15-2012, 03:36 PM Thread Starter
xcaliber81
Alright thanks
xcaliber81 is offline
post #32 of 39 Old 11-21-2012, 10:20 PM Thread Starter
xcaliber81
Do i have to get a different drive shaft? I was reading about a 1330 to 1310 flange swap is that necessary why swap it? Is there anything to look out for or thing i should be doing while swaping the axle, i'm going to lift it at the same time since it kind of makes sense why move the control arm brackets twice right i'm planning to go with a 4.5 inch lift. Also im going to space all wheels 5/8 and have the wider stance on the front and still gives me the option of rotating my tires.
post #33 of 39 Old 11-22-2012, 08:11 AM
WhiteOut
WhiteOut's Avatar
Get somewhere with experience to do your gear set up. That way you know they have done it before and since you'll buy the parts there as well, you'll have warranty. You'll need the flange adapter for the 8.8 swap,, IRO sells them.
As for the spacers, don't get 5/8" and it is perfectly legal to run spacers front and rear. If you only want that much less backspacing, just use a new wheel that takes that into account, otherwise you should be using SpiderTrax or similar spacers. Also, where are you moving the control arm brackets to and why?
WhiteOut is offline
post #34 of 39 Old 11-22-2012, 09:56 AM
riot1987
I used the flange off the exploder and just got new Ujoints and it worked out perfect with my existing DS
Build thread^^
riot1987 is offline
post #35 of 39 Old 11-22-2012, 11:05 AM Thread Starter
xcaliber81
I originally thought i would have to move them it seems now i don't so i will just do the axle swap for now. I don't just have the axle i have the entire explorer to strip down lol.
post #36 of 39 Old 11-22-2012, 11:17 AM
dusterdude
Depending on your states laws
dusterdude is online now
post #37 of 39 Old 11-22-2012, 11:21 AM Thread Starter
xcaliber81
My dad does inspections he isn't recommending i use wheel spacers, ill go offset all 4 wheels and have the front tries stick out a little more. I am i canada btw.
post #38 of 39 Old 11-22-2012, 01:58 PM
WhiteOut
WhiteOut's Avatar
Spacers will pass inspection in BC. He probably thinks you'll use the slip on kind which are not recommended.
WhiteOut is offline
post #39 of 39 Old 11-22-2012, 02:06 PM Thread Starter
xcaliber81
My dad told they would too but i feel better offsetting the wheels. having the wider stance on the front wont be such a bad thing and hardly be noticeable
