Rear end questions - Page 2 - JeepForum.com
post #16 of 39 Old 11-14-2012, 11:24 PM Thread Starter
xcaliber81
my zj has 3.55 gears, a friend said gear sets are cheap. I don't know what the exploder has I haven't looked yet. It's still at work.
xcaliber81 is online now
post #17 of 39 Old 11-15-2012, 07:14 AM
riot1987
I dont think gears are "cheap," no.
Build thread^^
riot1987 is offline
post #18 of 39 Old 11-15-2012, 07:32 AM
bridger04
1980 CJ7
Nothing is "cheap" in axles let alone our obsession with jeep
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Abraham Lincoln
bridger04 is offline
post #19 of 39 Old 11-15-2012, 10:20 AM
white_lexie
Does it matter if it came out of a 1995 2wd explorer, Do they still come with 32 spline axles and what ratio?
white_lexie is offline
post #20 of 39 Old 11-15-2012, 10:59 AM
JohnnyZJ
gears and install kit 300$ easy.
tools to install aren't cheap. labour at shop = expensive.
got a friend who can do it? with all the correct tools and knows how to do a gear setup? buy him pizza, beer, women, etc.
to do gear setups right is a pain. and many times you don't notice its wrong right away; its 6 months to a year down the road.
white lexie all explorer diffs are 31 spline. gear ratio could be anything. pull the cover and look. it is the only way to confirm what axle has what.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #21 of 39 Old 11-15-2012, 11:10 AM Thread Starter
xcaliber81
a ring and pinion for the 8.8 on summit is between 159 and 179$ and yes i know a transmission mechanic im not sure if he knows diffs though. What ill end up doing is matching the front eventually unless i luck out and its a 3.55 8.8 rear. It's an xlt awd and it has a leather interior. Not sure it has lsd
post #22 of 39 Old 11-15-2012, 12:02 PM Thread Starter
xcaliber81
my dad said its not legal to put spacers on the rear wheels, so i could get the rear wheels offset 5/8 instead of spacers, what will happen if i just leave it 5/8 shorter per side? My dad is a long time mechanic and is recommending me not to put spacers in but said anything is possible, but then if i got the offset wheels i couldn't rotate my tires.everybody i ask is telling me not to use spacers and 5/8 is too much to space.
post #23 of 39 Old 11-15-2012, 01:27 PM
white_lexie
Gear ratio isnt a big deal, so long as it has 31 spline axles. I think that I have found a steal on one off a 1995 2wd.
post #24 of 39 Old 11-15-2012, 01:28 PM
ajmorell
ajmorell's Avatar
You can get gear sets for that cheap but you get what you pay for.
ajmorell is offline
post #25 of 39 Old 11-15-2012, 01:50 PM Thread Starter
xcaliber81
Im open for suggestions this is a new thing for me if i can get a better quality ring and pinion i will, I won't be doing it until spring at the earliest.
post #26 of 39 Old 11-15-2012, 02:47 PM
JohnnyZJ
if its more than 5$ its not a steal.
you will be FAR better off knowing what ratio you have, and finding an appropriate 8.8 with the same ratio.
unless you are going to completely rebuild axles with new ring pinion, bearings etc.
xcaliber, wheel spacers are fine. just make sure you use locktite on the bolts holding the spacer to the hub and hand tighten them to the appropriate torque. take your time with these things. make sure they are tightened correctly etc. they are just fine.
last word for now; regearing an axle, even if its out, will likely come to 300$ - 500$ thats without labour. then keep in mind you are asking a mechanic/friend what ever to do about 500$ worth of work, using 1500$ worth of their tools, to save you money.
all i'm saying is this is a lot of work...... plan accordingly maybe your mechanic dad can do a gear swap for you! family HAS to help lol
JohnnyZJ is offline
post #27 of 39 Old 11-15-2012, 03:07 PM Thread Starter
xcaliber81
I already asked my dad and he said he could probably do the ring and pinion swap. I am probably going to do whats seems right and get 5/8 offset wheels for the rear.
post #28 of 39 Old 11-15-2012, 03:09 PM
ajmorell
ajmorell's Avatar
I was just looking back at my 8.8 build, I got NIB Yukon 4.56s for a little under $200 from Desert Rat Offroad. I know some people who have bought cheaper gears (Nitro, G2 and the like) have complained of excessive gear whine, I haven't heard or experienced that with my Yukons. If Desert Rat has them for that price get a set, everywhere else I've seen them they are $250+
ajmorell is offline
post #29 of 39 Old 11-15-2012, 03:16 PM Thread Starter
xcaliber81
i was looking for gear sets for the 8.8, im going to replace the front gear set. what are some good brands to watch for?
post #30 of 39 Old 11-15-2012, 03:26 PM
ajmorell
ajmorell's Avatar
I went with OE Dana-Spicer up front. Yukon would be my second choice.
ajmorell is offline
