Rear-end Noise. PLEASE HELP!!! - JeepForum.com
post #1 of 5 Old 04-29-2003, 07:46 PM Thread Starter
LouisC9999
My 97 Grand Cherokee makes a dull, grinding sound whenever I make slow, tight turns. It makes the same sound whether turning right or left. It sounds like it's coming from the rear, outer wheel bearings.
I had them replaced about a month ago and the noise went away--for a while. Now, I hear the noise only after having driven for an hour or more. It's been significantly diminished but still there.
Also, I hear a somewhat loud whirring sound when the vehicle is moving.
When I reported this to the shop, they told me that, since the outer wheel bearings have been recently replaced, they'd have to look at the 'pumpkin'.
They said that they could diagnose the problem only by tearing it apart. That's 6 hours labor which I'd have to pay for if they don't find anything wrong? My extended warranty will pay if there's a problem with the 'pumpkin'.
Does anyone out there have any direct experience with this problem or can offer suggestions as to what the problem might be?
Any feedback will be APPRECIATED.
2004 Grand Cherokee Limited
LouisC9999 is offline
post #2 of 5 Old 04-30-2003, 11:46 AM
RufftyTuffty
RufftyTuffty's Avatar
Sounds like the main axle bearings....do you know if the rear axle is the Dana 44 aluminium version or the regular Dana 35 ?
If it's the 44 then this whirring sound will most likely be the main bearings...common problem...had mine done @ 45k.
97 V8 TSi 7" RK LA/36s/4.88s/ARBs/TERA 60/8.8/Crane/PSC
RufftyTuffty is offline
post #3 of 5 Old 05-01-2003, 06:26 PM
JEEPTECHNICIAN
is it a v8 and does it do it when your turning into a parking space.
JEEPTECHNICIAN is offline
post #4 of 5 Old 05-07-2003, 07:40 AM
ZJohnR
Do you have limited slip diff? If so, have you had your diff oil changed? Perhaos they forgot (or didn't think) to put the limited slip additive in with the oil...
Silly me changed my diff oil last weekend and forgot to put it in and can hear it start...I had an IROC that the grease monkey dudes didn't put the additive in and it felt like the whole rear was gonna fall apart (felt 'lumpy') when I turned corners
1998 Jeep GC 5.9 Limited, RE 4.5" on 32's and more...
ZJohnR is offline
post #5 of 5 Old 05-07-2003, 01:07 PM
ILoveto4x4inNC
Mine was doing the same thing at about 50K, the dealer replaced all the bearings in it. Haven't heard anything in the last 20k. Gotta love that P.O.S. D44a.
This aint your daddy's Jeep!
'98 ZJ with 5.2L
Stock except for Optima red top
bigger tires(30x9.50 15 BFG MTs)
Rancho RS5000 shocks
swapped in NV231
and Pioneer CD deck.
White Jeep Club member #14
ILoveto4x4inNC is offline
Rear end noise Pomorza ZJ Grand Cherokee Forum 2 07-26-2009 10:35 PM
Right Rear End Noise iceref63 ZJ Grand Cherokee Forum 4 03-10-2008 11:57 AM
Noise from under rear end RedLion ZJ Grand Cherokee Forum 4 04-03-2007 08:23 AM
Rear end noise? splash56 ZJ Grand Cherokee Forum 0 02-09-2007 11:00 AM
Help with rear end noise ??? 69X55SS ZJ Grand Cherokee Forum 11 05-25-2005 03:26 AM
