Rear End Clunk...Differential Or Bushing? - JeepForum.com
post #1 of 5 Old 05-27-2011, 04:01 PM Thread Starter
JasonStebbins
I've acquired a new clunk that I've been hunting down for almost a month now. It happens when I come to a complete stop and accelerate from a stop. It sounds metallic and is pretty loud. I've replaced the rear u-joints, rear sway bar bushings, rear sway bar links, lower control arm bushings, rear shocks and rear pads. I also greased the slip joint and changed the differential fluid.
The Jeep has 199,600 miles on it so I'm concerned that the noise may be the differential bearings or spider gears going bad. I know the "rear end clunk" threads are cliche but other than this problem my Jeep runs and drives excellent.
Basically I'm asking whether or not track bar bushings or upper control arm bushings would make that significant of a noise. Because those are the only things I haven't replaced. It's not super loud but I can feel it in the floorboards every time it happens.
Poop
JasonStebbins is offline
post #2 of 5 Old 05-27-2011, 04:10 PM
m0l0
I would recommend checking your transfer/transmission mount, if you say you feel it on the floor, bearings never clunk, they whine or zuumm kind of. and yes upper/lower ca bushings can clunk also.
m0l0 is online now
post #3 of 5 Old 05-27-2011, 05:40 PM Thread Starter
JasonStebbins
I forgot to mention I replaced my transmission mount. This clunk doesn't sound like a bad bushing though, it's pretty nasty. I was thinking more along the lines of backlash being off or play in the differential bearings.
Poop
post #4 of 5 Old 05-27-2011, 10:05 PM
jnicewan
I would like to think its probably a suspension bushing or CA bolt loose. Most of the time a axle has enough play to clunk like that it will be even more evident when shifting rev to drive or p/n to a gear. I have heard slip yolks do this too.
I would recommend a couple other steps you could take to try to determine the noise but I would probably get flamed and it could be considered dangerous to some people. Having the ability to lift the Jeep off the ground might help you find the noise.
jnicewan is offline
post #5 of 5 Old 05-27-2011, 11:58 PM
freakinheep89
I would think either control arm bushings, or wheel bearings.
But since there is no whine, im leaning towards CA bushings. they can make an awful thud when stopping and accelerating.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
Differential mount bushing replacement LelandGray WK Grand Cherokee & XK Commander Forum 6 10-06-2010 07:46 PM
What is a "differential pinion mount bushing"? jbwest17 WK Grand Cherokee & XK Commander Forum 12 05-10-2010 09:25 PM
Rear bushing slipping out after Addco rear sway bar install n8man1068 ZJ Grand Cherokee Forum 3 08-04-2009 02:27 PM
Clunk in reverse from rear differential mmstone ZJ Grand Cherokee Forum 7 12-29-2005 10:08 AM
Rear clunk, clunk, clunk Camo ZJ Grand Cherokee Forum 10 11-24-2005 08:17 AM
