rear driver turn signal inop - JeepForum.com
post #1 of 3 Old 09-25-2008, 07:35 AM Thread Starter
dredevil
driver rear turn signal inop , tried new bulb ,tried another bulb socket no help,all other signals work, please help
dredevil is offline
post #2 of 3 Old 09-25-2008, 07:52 AM
keith20mm
Examine the bulb holder contacts to verify contact. This is a common problem, and has been reported before, for turn signals, tail lights, and brake lights, in this, and other, Jeep forums. The contacts may need to be slightly bent.
Check the wires with a voltmeter to see if power is coming in to the housing connector.
keith20mm is offline
post #3 of 3 Old 09-29-2008, 11:21 AM Thread Starter
dredevil
thanks for info Keith20mm, I tried everything you said , the lens assy is bad
dredevil is offline
Left rear turn signal intermittant legerdemain ZJ Grand Cherokee Forum 4 12-07-2011 12:15 AM
I need help! Turn signal/ Turn signal switch problem orangepower1987 ZJ Grand Cherokee Forum 8 09-16-2009 12:19 AM
02 Wj Bizarre turn signal wont turn off mountcharles ZJ Grand Cherokee Forum 0 05-05-2009 03:51 PM
turn signal ? 95grcher ZJ Grand Cherokee Forum 8 03-30-2008 06:38 PM
LED Turn Signal Fix bsm413 ZJ Grand Cherokee Forum 8 11-30-2005 11:05 AM
