Rear Drive Shaft leak - JeepForum.com
post #1 of 4 Old 08-06-2006, 04:18 PM Thread Starter
micifus
Original GC'er
micifus's Avatar
The rear DS is leaking where it connects to the TC, just alittle not much.
How Bad is this?
How much to fix?
And should I bother
I6 with the AWD N 4-LO TC
and ummm..... what Trans Fluid should I use I say I was missing a bolt and the pan has leaked since I owned so tomarrow is tranny fluid replacement day
for a 93, Haynes says Mercon/Dextron III I assume they would not steer me wrong but I am just double checking
Ill be sure to take pics so you can point and laugh at the amount of metal chunks in my trans pan.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #2 of 4 Old 08-06-2006, 04:57 PM
goodolboy71
How Bad is this?
How much to fix?
And should I bother
first- the seal is an easy 5 min fix, grab one from the store, remove ds, pull old seal, use large socket to tap new one in...good to go
and DO NOT USE DEXTRON MERC in your TC, use ATF+3 or 4, i have a 42re and the dip stick says the same as yours but its worng.....unless of course you have a AW4 trans...in that case...i hate you
AW4= P-R-N-D-3-1/2
42re= P-R-N-D-2-1
93 ZJ, 4.0, np242, 4 in F>R , 33's, Arb Bumper, Warn XD 9000, Home depot Rack, lightfoce 170's and some blingy shny 5 star rims,8.8 lsd, d30 /ox locker, JCR Rock Rails
74 CJ5- total restoration from ground up, 3 spd, 304 V8, 32's
goodolboy71 is offline
post #3 of 4 Old 08-06-2006, 05:05 PM Thread Starter
micifus
Original GC'er
micifus's Avatar
no its the 42re whats the big deal with the AW4? Even haynes says to merc/dex. I am sure its had that in there for a long time. Ill go with the dex only then, I think I may have even poured some of that heavy tranny fluid in there too try and stop it from leaking.
oh and is there a tranny filter?
32"x11.5" BFG A/T
4" Lift
micifus is offline
post #4 of 4 Old 08-06-2006, 05:29 PM
goodolboy71
aw4= better than the crappy 42re.....i wouldnt use the merc....and yes there is a filter in the tranny
Rear drive shaft? DrGrebo ZJ Grand Cherokee Forum 1 01-24-2010 07:19 PM
Front Drive shaft-play and now leak??? paddingtonbear ZJ Grand Cherokee Forum 5 04-22-2009 01:29 AM
your recommendation please for rear hd drive shaft genislav ronen ZJ Grand Cherokee Forum 1 03-31-2009 02:44 PM
ZJ CV style rear drive shaft help Schwarzy ZJ Grand Cherokee Forum 3 03-30-2008 12:56 AM
