Rear door won't latch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rear door won't latch
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-05-2012, 03:36 PM   #1
hdrocknroll
I opened the door now it just won't latch.
It looks like it is in the right position, but acts just like it would if you were pulling on the inside handle and trying to shut the door.
What do ya think is it a rod stuck, or is the problem inside the latch ???
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
[QUOTE=rooster51;13297693] Whats the worse that can happen? Your jeeps already broke.
[/QUOTE]
hdrocknroll is offline   Reply With Quote Quick reply to this message
Unread 07-05-2012, 03:59 PM   #2
AnotherRedZj
Use a screwdriver to try and move the latch while workin the door handle. See if its locked up. I've had a latch get set backwards after it gets shut to hard before, hope its that simple for you.
AnotherRedZj is offline   Reply With Quote Quick reply to this message
Unread 07-05-2012, 04:04 PM   #3
JasonStebbins
Take off the panel and look inside. There is a rod that pushes into a small plastic bracket, commonly falls out. Very similar to the rear hatch.
JasonStebbins is offline   Reply With Quote Quick reply to this message
Unread 07-05-2012, 06:47 PM   #4
hdrocknroll
Well I couldn't really find any thing wrong with it.
I think the springs in there a little weak, and it was gummed up.
Took it all apart, cleaned it up, lubed it with lithium grease, and it works good now.
I am glad !! I took it apart very slowly, cuz the little springs started popping out, but I got them all back where they belong.
[/QUOTE]
Unread 07-05-2012, 07:49 PM   #5
KoreaZJ
1994 ZJ
Mine do the same thing in temps below 10-15F. Just gummed up with old dried lube. I spray liquid wrench into the latch while opening/closing the door several times. Then spray white lithium grease in and exercise it some more.
So far I haven't needed to remove the latch.
KoreaZJ is offline   Reply With Quote Quick reply to this message
door latch
