Rear door won't latch - JeepForum.com
post #1 of 5 Old 07-05-2012, 02:36 PM Thread Starter
hdrocknroll
I opened the door now it just won't latch.
It looks like it is in the right position, but acts just like it would if you were pulling on the inside handle and trying to shut the door.
What do ya think is it a rod stuck, or is the problem inside the latch ???
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 5 Old 07-05-2012, 02:59 PM
AnotherRedZj
Use a screwdriver to try and move the latch while workin the door handle. See if its locked up. I've had a latch get set backwards after it gets shut to hard before, hope its that simple for you.
AnotherRedZj is offline
post #3 of 5 Old 07-05-2012, 03:04 PM
JasonStebbins
Take off the panel and look inside. There is a rod that pushes into a small plastic bracket, commonly falls out. Very similar to the rear hatch.
JasonStebbins is offline
post #4 of 5 Old 07-05-2012, 05:47 PM Thread Starter
hdrocknroll
Well I couldn't really find any thing wrong with it.
I think the springs in there a little weak, and it was gummed up.
Took it all apart, cleaned it up, lubed it with lithium grease, and it works good now.
I am glad !! I took it apart very slowly, cuz the little springs started popping out, but I got them all back where they belong.
post #5 of 5 Old 07-05-2012, 06:49 PM
KoreaZJ
1994 ZJ
Mine do the same thing in temps below 10-15F. Just gummed up with old dried lube. I spray liquid wrench into the latch while opening/closing the door several times. Then spray white lithium grease in and exercise it some more.
So far I haven't needed to remove the latch.
KoreaZJ is offline
door latch
Grande Cherokee door latch will not latch arory1@shaw.ca ZJ Grand Cherokee Forum 14 02-25-2015 09:36 AM
ZJ rear door latch schematic? jfiscus ZJ Grand Cherokee Forum 4 02-04-2014 08:46 PM
door latch bteixeira02 ZJ Grand Cherokee Forum 8 07-02-2012 09:48 PM
door latch? mudder53 ZJ Grand Cherokee Forum 2 08-31-2011 05:26 PM
GC door latch, wont latch arory1@shaw.ca ZJ Grand Cherokee Forum 0 03-02-2009 08:33 AM
