Rear Differential Oil Change Questions...? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rear Differential Oil Change Questions...?
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 01-21-2005, 08:05 AM   #1
jo8243
I'm going to change the rear differential oil in my '02 2WD Grand Cherokee w/ limited slip diff.
What is the tightening torque for the diff cover bolts?
To access everything the easiest, should I jack the jeep up by the frame and put it on jackstands to the suspension will uncompress or will driving the rear up on rhino ramps be enough?
Thanks
jo8243 is offline   Reply With Quote
Unread 01-21-2005, 08:18 AM   #2
greasefingers
1994 ZJ
If anything, jack the front up after you remove the rear pumpkin cover, to allow more oil to drip out. There is plenty of room to work without jacking the vehicle up. I always try to avoid jacking the jeep up, if I can avoid it, for safety reasons. The torque for my, much older jeep, is 33 ft-lbs.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Unread 01-21-2005, 08:38 AM   #3
Red Menace
I just did my axles and I torqued them down to 30 foot pounds.
Matt
[url=http://img.photobucket.com/albums/v243/Red_Menace/DSC01169-centered-croped.jpg]01 V8 Black WJ - OME+BB - Carsound - Flowmaster 40 - TC Intake[/url]
Red Menace is offline   Reply With Quote
Unread 01-21-2005, 11:55 AM   #4
pgv98
1997 XJ Cherokee
you can always just pump out the old and pump in the new. It is very easy and takes about 15 minutes. The pumps can be bought at any auto parts store for about 3 to 5 dollars. The disadvantage of this method is you don't get it quite as clean as when you take off the cover. But for me, more frequent changes will occur the easier it is. I try to change it out every time I drive through deep water.
1997 Jeep XJ sport
4x4
150,000+
pgv98 is offline   Reply With Quote
