Rear diff leaking question - JeepForum.com
post #1 of 5 Old 05-17-2004, 08:07 AM Thread Starter
shelter1
anyone make something better than the rubber plug for the rear end of a 97 grand cherokee??? and aftermarket cover with a true drain plug??? or just put some silicone sealent around it????
shelter1 is offline
post #2 of 5 Old 05-17-2004, 09:01 AM
cfoxmd
I put some RTV sealant around mine.
cfoxmd is offline
post #3 of 5 Old 05-17-2004, 11:07 AM
900Steve
i supposed if you have some fabrication skills, time and tools you can weld a bung into it, or find a pre-fab bung that just requires drilling and fastening/sealing into the existing cover.
i hear you, i keep putting off changing diff. fluid because i don't want to deal with the mess. but a fluid change is a good excuse to open them up and inspect the internals from time to time.
-steve
4.0L, 94 ZJ
900Steve is offline
post #4 of 5 Old 05-19-2004, 07:39 AM Thread Starter
shelter1
fixed it
the silicone fixed it, no luck finding an aftermarket cover.
shelter1 is offline
post #5 of 5 Old 05-19-2004, 09:22 AM
cfoxmd
Only problem with the silicone is that when you go to check the level, you break the seal and the leak is back. I guess you just have to clean the plug and put new sealant on it.
cfoxmd is offline
rear diff leaking oldfamilyguy ZJ Grand Cherokee Forum 2 11-22-2009 03:51 PM
Rear Diff repaired/replaced, now leaking elsewhere. Normal? chromedisguise ZJ Grand Cherokee Forum 26 10-08-2009 02:06 PM
98 JGC: Leaking rear diff at driveshaft seal shudog ZJ Grand Cherokee Forum 10 10-03-2009 11:53 PM
'94 GC rear diff question sdog30 ZJ Grand Cherokee Forum 5 01-05-2006 08:28 AM
leaking power steering fluid and rear diff fliud??? 2tone93zj ZJ Grand Cherokee Forum 3 05-10-2005 12:45 PM
