rear defog - JeepForum.com
post #1 of 2 Old 01-13-2003, 10:38 PM Thread Starter
rJEEP
rear defog
My rear defog doesnt work. What are all the things I can check? Where should I start?-thanks
98 ZJ 4.0 HO
rJEEP is offline
post #2 of 2 Old 01-14-2003, 10:34 AM
automan25
Your rear defogger doesn't work because there is a break in the electrical circuit somewhere. Most likely it's at the point where the wires connect with the heating element that is fixed to the rear window. You'll need to use a multimeter to check for voltage running through the circuit.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
Electrical issues..dome lights, rear wiper, rear lift glass. sbrunner ZJ Grand Cherokee Forum 8 07-18-2014 06:48 PM
Rear bushing slipping out after Addco rear sway bar install n8man1068 ZJ Grand Cherokee Forum 3 08-04-2009 02:27 PM
dulling clear coat bottom rear of rear doors Hillbillydeluxe WK Grand Cherokee & XK Commander Forum 9 04-24-2009 09:29 PM
Replacing rear wheel and rear axle bearings? pulsepb ZJ Grand Cherokee Forum 4 02-21-2009 12:47 AM
zj front to rear spring 4" lift rear track bar info autobeamhotmail ZJ Grand Cherokee Forum 3 03-01-2007 03:07 PM
