Rear clunking noise solved..finally - JeepForum.com
post #1 of 4 Old 03-28-2005, 01:32 PM Thread Starter
greasefingers
greasefingers's Avatar
1994 ZJ
I finally found a loud clunking noise in the Jeep. It has been driving me crazy for three months. It turns out that it was one of the lower rear shock bolts. I had to break the bolt to get it off. Since it is a OD bolt I used a breaker bar and -drive sockets. Once off, I could see that the outer diameter of the bolt had worn down to a much smaller size. When I would hit a bump, the shock would travel in the slop first, before compressing and doing its normal job. This created a clunk clunk clunk. I cannot explain why the bolt wore so badly. The shock only partially rotates around this bolt by a couple of degrees. Maybe rust and dirt get in there?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #2 of 4 Old 03-28-2005, 02:18 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
The stock bolts are 12mm tapered...don't ask me why they are tapered.
Had the same thing happen. Pressed some new 5/8" hourglass poly bushings in the shock hoops. Then pressed in some 1/2" ID bushing sleeves out of a Rancho install kit. Then finished up with 1/2" grade 8 bolts. Haven't heard anything from the rear suspension for years.
Link to bushings 9.8107
http://www.energysuspension.com/pages/sk_bsp1.html
HighLonesome is offline
post #3 of 4 Old 03-28-2005, 07:32 PM Thread Starter
greasefingers
1994 ZJ
yea...real hillbilly setup on the stock set-up. I got them on good & tight with some of my own tricks. It aint going nowhere now.
Cheers Steve
post #4 of 4 Old 01-05-2011, 08:44 PM
jdk3034
sorry to bring up an old thread, but can you replace the factory tapered lower rear shock bolts with a standard shank 10.9 12mm bolt?
jdk3034 is offline
45RFE limp solved finally rxl ZJ Grand Cherokee Forum 23 04-04-2015 12:14 PM
Finally, Transmission problem solved a_kraker99 WK Grand Cherokee & XK Commander Forum 5 04-17-2009 09:35 AM
rear clunking noise rrock724 ZJ Grand Cherokee Forum 6 01-22-2008 11:53 PM
Clunking noise from right rear tire (Question) onrails ZJ Grand Cherokee Forum 3 11-07-2006 02:41 PM
Whining noise solved (wana know?) dscott98GC ZJ Grand Cherokee Forum 2 05-10-2005 06:46 AM
