rear bumper - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > rear bumper
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive GarRuffStuff Memorial Day Sale!
Unread 04-23-2008, 03:43 PM   #1
inlinegrand6
rear bumper
What is the right way to take out the black plastic rivets on the inner wheel well that hold the rear bumper fascia on? I could take them off if I didn't care about using again, but I'd like to know the non-breaking way. thanks
inlinegrand6 is offline   Reply With Quote
Unread 04-23-2008, 06:39 PM   #2
jeepheller98
i nice trick is to use a pair of scissors..not to cut them but they are thin enought to squeeze behind and leverage them out, a thin needle nose works well.. the key is not to put to much pressure on one side but try to pull straight.... but seriously go to the auto store and pick up new ones for $3 cuase no matter what you are going break some/step on some..
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline   Reply With Quote
Unread 04-23-2008, 07:23 PM   #3
blovingier
blovingier's Avatar
A wonder bar (tiny pry bar) works pretty good to get them off.
"GRITZ"
Proud Godfather of a Red TJ(will add specs later)
In process of buying - 2000 Jeep Grand Cherokee Laredo
99 Jeep Grand Cherokee Laredo - Totalled
-3" lift w/Bilsteins - - - - - - - - - - - - - - - - - -30.5" Pirelli Scorpion ATRs
-Clear Lenses - - - - - - - - - - - - - - - - - - -Cobra 75 CB w/Wilson 4' Antenna
-Home-Brew Discos- - - - - - - - - - - - - - - - - -Diamond Plate Hitch Cover
07 Compass (wife's ride)Sold
-Stock
blovingier is offline   Reply With Quote
Unread 04-23-2008, 09:14 PM   #4
Vestjam
Vestjam's Avatar
I use a "door trim" tool. It will fit in between the two pieces and then allow you to pry the top one out and away to release the whole piece. My wheel well ones (98ZJ and 95ZJ) have a plastic phillips head screw the will back out as you turn is slowly. Then the whole thing pops out.
2008 Jeep Wrangler X (Hard Top)
Incubus Off Road 511's with BFG 285/70-17
1998 Jeep Cherokee Sport
4.0L/AW4, Yakima Roof Rack
Vestjam is offline   Reply With Quote
Unread 04-23-2008, 09:16 PM   #5
FlipFlop425
I used a little claw ripping bar that I had.
04 WJ Columbia Edition 4.0
WJ Wheels For Sale!!!
FlipFlop425 is offline   Reply With Quote
