rear bump stops - JeepForum.com
post #1 of 7 Old 08-26-2011, 10:28 AM Thread Starter
white_lexie
rear bump stops
Where can you find these at, mine are completely gone and I gotta have some new ones asap but cannot find them anywhere?
white_lexie is offline
post #2 of 7 Old 08-26-2011, 11:16 AM
Technohead
The dealership.
Instead of replacing the stock bumpstop I would recommend building your own using off-the-shelf components from Poly Performance, Daystar, etc.
-Eric
Technohead is offline
post #3 of 7 Old 08-26-2011, 12:24 PM
LordHobbit
hockey pucks.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #4 of 7 Old 08-26-2011, 12:59 PM
Derph
1994 ZJ
Originally Posted by LordHobbit
hockey pucks.
Really?! Will this work with the front as well?
Derph is offline
post #5 of 7 Old 08-26-2011, 05:30 PM
ZJJay
ZJJay's Avatar
My '96 ZJ has a 4-1/2" lift. The rear bump stops are Daystar P/N KU09022BK and the fronts are P/N KJ09101BK.
'96 ZJ, 4.0L, 42RE, NP242, stock D30 and D35-LS w/ 3.73, 4-1/2" lift, 32" BFG ATs, Magnaflow, JKS track bars and disconnects, spare tire carrier, Optima red top, ROLA roof rack, KC SlimLite driving lights, CB and Yaesu ham radios, GPS
ZJJay is offline
post #6 of 7 Old 08-26-2011, 08:04 PM
Technohead
Don't use hockey pucks for bump stops. You might as well use steel because they absorb about as much energy. Hockey pucks are OK if you have a working bump stop and need to reduce the suspension travel a bit.
-Eric
post #7 of 7 Old 08-26-2011, 08:47 PM
Derph
1994 ZJ
Dint think they would work right. But I honestly didn't know about the extention!
Derph is offline
ZJ Extended rear bump stops?? Cody1 ZJ Grand Cherokee Forum 13 01-28-2014 05:03 AM
I need bump stops!!! MoToRNecK ZJ Grand Cherokee Forum 10 08-05-2010 01:43 PM
bump stops and rear swaybar? DrGrebo ZJ Grand Cherokee Forum 6 03-01-2010 08:12 PM
Rear bump stops ZJenvy ZJ Grand Cherokee Forum 27 08-15-2007 04:45 PM
Bump Stops Crunch ZJ Grand Cherokee Forum 4 06-24-2007 09:15 PM
