Rear bump stop gone,how get off,see pic - JeepForum.com
post #1 of 8 Old 03-07-2012, 11:39 PM Thread Starter
hdrocknroll
How would U normally replace the bump stop ? Stock,no lift
Right side is gone but I don't see how to get the cup thing off.
In the pic, does this look right or is something missing besides the rubber ???
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 8 Old 03-07-2012, 11:47 PM
squazz
looks like there is 2 bolts holding it on good luck with getting a socket on and not breaking them
squazz is offline
post #3 of 8 Old 03-08-2012, 12:02 AM Thread Starter
hdrocknroll
That's what I was thinking, they might snap.Rusty
I wasn't sure those were even bolts.
After pic soaked every thing down with ATF mix.but that's no guarantee they wont snap
Got new shocks to put on but also need to fix this.
I will dig the crap out in there so I can see
What holds the rubber in ??
post #4 of 8 Old 03-08-2012, 12:06 AM
squazz
i believe it just jams in there like the front ones do
squazz is offline
post #5 of 8 Old 03-08-2012, 12:26 AM Thread Starter
hdrocknroll
So !! can I just clean it up and buy new rubber and jam it in ??
post #6 of 8 Old 03-08-2012, 12:57 AM Thread Starter
hdrocknroll
Couldn't find this info in FSM, found pic on line.
Looks like I can replace rubber,with out removing cup, if I can where to buy one.
post #7 of 8 Old 03-08-2012, 01:01 AM
TheHalfWit
Contact kolak, he set me up with extended ones when I was ordering parts for my lift, I'm sure that he can furnish stock length ones for you.
Bit more expensive then the spacer that rubicon express does, but my cup looks exactly like yours so I don't think removal is possible without redoing the nutsert.
Yea, if you yank the other one you'll see how it fits in. The cup has metal tangs that grab the bump stop and lock it in place, the bump stop has little holes (indents) on the bottom where the bolt heads stick out. (I don't advise you to yank the other one before you're changing it though. it might be a good idea to hit the mounts with a wire brush though to clean them up before you stick new bump stops in.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #8 of 8 Old 03-08-2012, 01:47 AM Thread Starter
hdrocknroll
Thanks good info
I wouldn't put new ones in with out cleaning the cups up .
Found some for 50 bucks,crazy for piece of rubber,oh wait maybe was for 2
As I was searching ,thought of Kolak
bump stop
getting ZJ rear bump stop questin? 4"RC sadass ZJ Grand Cherokee Forum 14 05-07-2015 12:22 PM
drilling out rear bump stop bolts? sevenscrew ZJ Grand Cherokee Forum 8 03-21-2014 10:14 PM
bump stop help! overboostin WK Grand Cherokee & XK Commander Forum 1 05-23-2011 07:20 AM
Rear Bump Stop Question ntaousakis ZJ Grand Cherokee Forum 9 01-13-2008 09:25 AM
Bump Go !!!, (Opposite of stop bump) madmarchhare ZJ Grand Cherokee Forum 7 08-25-2006 07:04 PM
