Rear brake issue 96 ZJ pics inside - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rear brake issue 96 ZJ pics inside
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread Yesterday, 09:14 PM   #1
jswerve
Pulled the wheels off of my 96 ZJ (4.0) and found this;
Guessing this is caused by the caliper nesting in those groves over a long period of time? Here's a photo of the pad wear;
Notice it is wearing uneven on the left closest pad and far right back pad.
Rotor;
2001 WJ 4.0 Selec-trac
1996 ZJ 4.0 Selec-trac
jswerve is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 09:18 PM   #2
CatSplat
Derp.
CatSplat's Avatar
1994 ZJ
Fill the grooves with some weld, grind flat, install new pads. Really common issue with the ZJ brackets.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 09:20 PM   #3
jswerve
Hey thanks for the quick reply. I am in my driveway lol. No welder available. I don't imagine these brackets come off too easy?
Unread Yesterday, 09:45 PM   #4
jm8881
Add rotors to that.
2WD Cubby For Sale: http://www.jeepforum.com/forum/f130/zj-vic-delete-cubby-3118649/
jm8881 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:50 PM   #5
jswerve
Originally Posted by jm8881 View Post
Add rotors to that.
Haha yeah I was thinking the same. Now I need to get the dang things off. Not sure on these with the emergency brake and all.
Unread Yesterday, 10:17 PM   #6
Uniblurb
Uniblurb's Avatar
You should be able to get the rotors off. Spray around the hub/studs with a good rust cutter, screw the lug nuts on a little to protect the stud threads, then hit the face of the rotor between the lugs with a bfh!
If you don't know what the ebrake looks like inside here's a write up I did on fixing the seized cam/lever. If the shoes end up holding the rotor drum on some just follow the reverse procedure for tightening out the adjusters at the end of the thread.
http://www.jeepforum.com/forum/f13/e...te-up-1605033/
Best to get those grooves filled with weld as was already mentioned first. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 10:26 PM   #7
jswerve
Awesome, thanks Uni!
Unread Yesterday, 10:37 PM   #8
Uniblurb
Uniblurb's Avatar
Appreciate the thanks and glad it helps jswerve!
Unread Today, 05:19 AM   #9
marduksenforcer
There's nothing Uni can't do! He has helped me more times than I can count, and his links are always informative and help save money and time.
He's a ZJ owners best friend.
-AJ
marduksenforcer is offline   Reply With Quote Quick reply to this message
Unread Today, 08:22 AM   #10
CatSplat
Derp.
CatSplat's Avatar
1994 ZJ
Not particularly hard (the bracket/backing plate assy is only held to the axle via 4 bolts) but you do have to disconnect and remove all of the parking brake hardware, which can be a pain. You'll likely be battling some rust on the bolts as well, a good penetrant soak is probably a good idea.
An alternative to having them welded is to buy new ones from Crown.
Also I totally missed the pics of the rotor - yeah, you're going to need new ones, that look pretty thrashed.
The Jeep of Theseus
Unread Today, 08:33 AM   #11
jswerve
Thanks for the tip. Those are pretty spendy. I am doing rotors and pads all around and I will take it out to a friends shop afterwards and see if he can weld and grind the OEM brackets.
Unread Today, 08:36 AM   #12
CatSplat
Derp.
CatSplat's Avatar
1994 ZJ
Aye, a buddy with a welder is definitely the easier and cheaper way to do it! Your front caliper brackets will probably need the same treatment while you're at it.
The Jeep of Theseus
Unread Today, 08:38 AM   #13
jswerve
Unfortunately, you are correct.
