rear axle swap. - JeepForum.com
post #1 of 9 Old 07-24-2011, 02:56 PM Thread Starter
93ZJDave
rear axle swap.
so im pretty sure all the seals and bearings are shot in my rear i found a good axle out in the junkyard i think the grand was a 96 4.0 auto has rear disc brakes what gear ratio is in it did the dana 35 come with disc brakes in the grand cherokee? any info would be great thanks. here's the axle tag off my current axle im not sure how to tell whats what
93ZJDave is offline
post #2 of 9 Old 07-24-2011, 03:38 PM
sd15gibbs
93 was the only year with drum brakes. should have 3.55's
sd15gibbs is offline
post #3 of 9 Old 07-24-2011, 03:42 PM Thread Starter
93ZJDave
im not 100% but i blew the rear out while ago and replaced the gears and what not im pretty sure mine 3.73's
93ZJDave is offline
post #4 of 9 Old 07-24-2011, 03:54 PM
CatSplat
1994 ZJ
Your diff will have 3.55's or 3.73's depending on having tow package or not. The same goes for the '96 4.0. You will need to verify the gear ratios match before swapping.
Edit: That tag picture is hard to read, but if it is 53007557, then it should have come from the factory with 3.55s and no Trac-Lok. The "55" on the second row also indicates 3.55 gears. (11 = 4.11, 55 = 3.55, 73 = 3.73) If I were you, I'd be checking to see what's stamped on the ring gears to make sure.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #5 of 9 Old 07-24-2011, 07:37 PM Thread Starter
93ZJDave
hmmm i think i put 373s in my rear which would mean i had 355 in the front my jeep is a 5spd if that makes a difference i think im just gonna get 411's or 456's for it so i know what gears are in it.i just dont know what gears i wanna run in it i use it as a daily driver when its not broken lol. but i do wheel it every now and then would i be better off with 410's or 411's? over the 456's?
93ZJDave is offline
post #6 of 9 Old 07-25-2011, 08:54 AM
LordHobbit
Make sure whatever you do, you match the front axle.
I wouldn't go any numerical number higher than 3.73 unless you get bigger tires.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #7 of 9 Old 07-25-2011, 11:01 PM Thread Starter
93ZJDave
im most likely not going any bigger then 33x13.50s i still dont know what gears i have in my jeep i still think 373s but idk thats what i was told wee in it
93ZJDave is offline
post #8 of 9 Old 07-26-2011, 08:32 AM
LordHobbit
If you get 33s then go with 4.56 gears. Your speedo will be mostly accurate, and you'll get the power you need to the wheels.
post #9 of 9 Old 07-26-2011, 11:31 AM Thread Starter
93ZJDave
Ill have to get them ordered I ordered my long arm lift to fix my upper control arm problem so now I need the gears
93ZJDave is offline
WJ Rear Axle Swap ArmyWJ WJ Grand Cherokee Forum 36 06-12-2013 06:53 PM
rear axle swap Darman ZJ Grand Cherokee Forum 22 06-15-2011 09:55 AM
rear end/axle swap rannej ZJ Grand Cherokee Forum 5 11-29-2008 02:21 AM
9.25 Rear Axle Swap for WJ? StrokedWJ ZJ Grand Cherokee Forum 7 10-12-2008 03:43 AM
D35 to D44 Rear Axle swap Q's GrandFormer2134 ZJ Grand Cherokee Forum 15 12-21-2006 10:08 PM
