Rear axle off center - Page 3 - JeepForum.com
post #31 of 60 Old 10-24-2011, 06:32 PM Thread Starter
JeepFreak1982
If this is how it's designed than so be it but i would be very dissapointed in Jeep if thats the case.
JeepFreak1982 is offline
post #32 of 60 Old 10-24-2011, 06:36 PM
david4127
Speaking of the axle any one ever hear of a Dana 44 hd i took mine to a jeep shop trying to get a nicer looking diff cover mine is getting rusted but I figured why not do an arb some thing that holds more fluid that will cool better is it really called a 44hd never herd of that b4
david4127 is offline
post #33 of 60 Old 10-24-2011, 06:41 PM Thread Starter
JeepFreak1982
The Dana 44A and Dana 44 HD are the same axle. It was used in the ZJ, WJ, and WK of all models including the SRT8 WK A lot of people hate on it because of the aluminum pumpkin but the fact of the matter is it's a very strong axle. It's a totally different design than a standard Dana 44 though and there are very few covers made for it. They are all $200+
post #34 of 60 Old 10-24-2011, 06:44 PM
david4127
Yea the arb they offered me was 215 +tax and they said that's with a discount
post #35 of 60 Old 10-24-2011, 06:47 PM
david4127
I also was wanting to find a 44 for the front any ideas what model to find a good 1 off of
post #36 of 60 Old 10-24-2011, 07:13 PM Thread Starter
JeepFreak1982
Only bolt in front 44 would be from a 03-06 TJ Rubicon. You would have to re gear the rear to match and have a new front driveshaft made. Plan on spending $3000 said and done. The D30 is plenty strong if you ask me. What are you doing that you feel you need a 44 up front?
post #37 of 60 Old 10-24-2011, 07:16 PM
david4127
I'm going to drop in a 380 hp motor I've been building was told need to re gear and put at least a 44 up front
post #38 of 60 Old 10-24-2011, 07:23 PM
david4127
I took a 5.9 engine had it machined had the heads machined put forged pistons light weight racing Edelbroch camshaft edlebroch performance lifters and push rods hi flow headers flow master exaust I am working on getting a super charger also have custom mapping done said if I super charge it would be too much for the 30
post #39 of 60 Old 10-24-2011, 07:32 PM Thread Starter
JeepFreak1982
Guys on another forum running 500+ HP on the stock 44a rear and d30 front axle. Get rid of the POS front CV shafts and put in a set of u joint shafts from a TJ or XJ with ABS Big upgrade right there. Whoever told you that you need "atleast" a 44 up front is wrong.
post #40 of 60 Old 10-24-2011, 07:36 PM
david4127
It's a performance 4x4 shop here probably trying to rip me off I know the engine don't know about axles I used to upgrade ricers never again I hate ricers now but never had to worry about axles
post #41 of 60 Old 10-24-2011, 07:39 PM Thread Starter
JeepFreak1982
www.thespeedfreaks.net
Eveything you wana know about building a performance ZJ Mostly 5.9 owners with some serious rigs. My user name there is Jeep98ZJ
post #42 of 60 Old 10-24-2011, 07:39 PM
david4127
It was a performance jeep shop they were probably trying to get some unnecessary business I know engines don't know much about axles
post #43 of 60 Old 10-24-2011, 07:41 PM
david4127
I'll check it out thanks
post #44 of 60 Old 10-24-2011, 07:43 PM
david4127
I know most 5.9s have black interior any ideas where to find good interior pieces can't find any at salvage yard
post #45 of 60 Old 10-24-2011, 10:53 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by JeepFreak1982 View Post
So i am told the ZJ with the 44A rear has an offset pumpkin and every one of them came from the factory with the axle out the passenger side 1" more than the drivers side. Im told they did this to keep the driveshaft at the proper angle. Anyone with a V8 ZJ with the 44A wana run outside and see if yours is like this also? Drivers side tire sits farther in the wheel well than the passenger side tire.
Thats completely absurd. The axle was custom built by dana FOR the zj. Its the ONLY vehicle you will find that set up in.
ratmonkey is offline
replacing WK 05 rear center cup holder & rear windshield wiper sfall WK Grand Cherokee & XK Commander Forum 1 07-31-2012 04:40 PM
nocked fron axle out of center? FrankTheDank ZJ Grand Cherokee Forum 5 10-31-2009 10:21 AM
Jeep pulls to one side after alignment. Can the rear axle being off center do this? bjl95mustang ZJ Grand Cherokee Forum 5 10-06-2009 02:44 PM
axle off center stiller ZJ Grand Cherokee Forum 4 03-23-2009 04:54 PM
off center axle - adj track bar for 3"? QuadraTokn ZJ Grand Cherokee Forum 21 03-25-2007 05:01 PM
