Rear axle off center - Page 2 - JeepForum.com
post #16 of 60 Old 10-23-2011, 10:16 AM Thread Starter
JeepFreak1982
I did that before installing it. They are both exactly the same and the axle sits in the exact same spot with both track bars.
JeepFreak1982 is offline
post #17 of 60 Old 10-23-2011, 10:28 AM
sabzz
Take a picture to show everybody whats going on.
1998 ZJ 4.0 work in progress/DD
'97 ZJ 4.0|3.5 RC|31" -SOLD
sabzz is offline
post #18 of 60 Old 10-23-2011, 10:28 AM
WhiteOut
WhiteOut's Avatar
Then it is an issue with the mounts, one is probably bent a bit.
WhiteOut is offline
post #19 of 60 Old 10-23-2011, 10:32 AM Thread Starter
JeepFreak1982
Ill get a picture up before the end of the day. If you look at the jeep from the passenger side the rear tire is flush with the wheel well. If you look at it from the drivers side the tire is tucked in pretty good.
post #20 of 60 Old 10-23-2011, 03:58 PM
Ripper3494
its either the mounts then or dumb question, do you have aftermarket rims? and is it at all possible that they have a slightly different backspacing? because that would definitely do it
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #21 of 60 Old 10-23-2011, 04:29 PM Thread Starter
JeepFreak1982
Stock 5.9 rims Im going to double check the control arms are matching part # pairs front and rear. It may mean nothing if they arent but just for me lol. I asked before but didnt get an answer. The lower control arms have the bushings sticking out one side more than the other. Does it matter how they go in? Id think with them being that way that maybe that could shift the axle over to one side or the other?
post #22 of 60 Old 10-23-2011, 04:33 PM
PolkaPower
Not that much to notice. I have a 2" BB with stock everything else and I have to look really close to see the axles difference.
PolkaPower is online now
post #23 of 60 Old 10-23-2011, 05:00 PM Thread Starter
JeepFreak1982
That has nothing to do with the control arms though. BB is just 2" spacers on the coils. I have owned the Jeep for over 2 years and never noticed anything till i did the control arms. Im going to have to pull the lowers front and rear one at a time and check em. I know it doesnt make sense but thats all i can think of. I have owned a lot of Jeeps and installed a lot of lifts over the years. I know how the track bar length works and all the rules behind everything. Doesnt make any more sense to me that you guys lol.
post #24 of 60 Old 10-23-2011, 11:46 PM
power
1994 ZJ
Sorry for the mis-leading info I posted, I wasn't thinking straight. I removed/edited this post it so as not to confuse anyone further.
My wrong info is quoted below in post 28.
94 ZJ,4.0, AX15, NP231
Last edited by power; 10-24-2011 at 07:34 PM. Reason: mis-leading/wrong information.
power is offline
post #25 of 60 Old 10-24-2011, 01:15 AM
moggie99
Photos would be useful...............
Richard Moss
'96 ZJ 4L auto, '95 XJ 4L manual, 2000 Nissan Patrol Y61
In the UK: 1969 MGC GT
moggie99 is offline
post #26 of 60 Old 10-24-2011, 01:54 AM
zachjf
Gotta be a bent bracket on either the axle or the body, its a physical impossibility for the control arms to misalign the axle to one side or the other with the trackbar installed.
Needs parts?
PM
or
zachjf is offline
post #27 of 60 Old 10-24-2011, 09:06 AM
PolkaPower
Yes, it has nothing to do with the control arms. When you raise the Jeep the front axle moves to the right while the rear moves to the left because of the track bars.
post #28 of 60 Old 10-24-2011, 05:40 PM
WhiteOut
WhiteOut's Avatar
Originally Posted by power View Post
I know some of the older ZJ's had slightly adjustable lower control arms. Not sure about the later years like yours. When I changed out my rear end recently I had to mark the lower control arm nut position at the axle when i removed it. The rear bolt had like 1/2" play in it either way. I had to move the jack around on the rear differential to be able to get the lower control arms the same as length as when I removed it. My Hanes manual (which I don't trust) says 1998 and early models may have had this lower control arm adjustment.
Cam bolts are only in the front, you didn't need to mark the rear. A messed up bolt or hole does not make something adjustable, it makes it broken.
WhiteOut is offline
post #29 of 60 Old 10-24-2011, 06:21 PM Thread Starter
JeepFreak1982
So i am told the ZJ with the 44A rear has an offset pumpkin and every one of them came from the factory with the axle out the passenger side 1" more than the drivers side. Im told they did this to keep the driveshaft at the proper angle. Anyone with a V8 ZJ with the 44A wana run outside and see if yours is like this also? Drivers side tire sits farther in the wheel well than the passenger side tire.
post #30 of 60 Old 10-24-2011, 06:30 PM
david4127
Mine is off set to the right slightly
david4127 is offline
replacing WK 05 rear center cup holder & rear windshield wiper sfall WK Grand Cherokee & XK Commander Forum 1 07-31-2012 04:40 PM
nocked fron axle out of center? FrankTheDank ZJ Grand Cherokee Forum 5 10-31-2009 10:21 AM
Jeep pulls to one side after alignment. Can the rear axle being off center do this? bjl95mustang ZJ Grand Cherokee Forum 5 10-06-2009 02:44 PM
axle off center stiller ZJ Grand Cherokee Forum 4 03-23-2009 04:54 PM
off center axle - adj track bar for 3"? QuadraTokn ZJ Grand Cherokee Forum 21 03-25-2007 05:01 PM
