Rear axle off center - JeepForum.com
post #1 of 60 Old 10-22-2011, 10:19 PM Thread Starter
JeepFreak1982
Rear axle is out the passenger side more than the drivers side. Brand new upper and lower control arms, new swaybar links and frame bushings, new MOPAR track bar, whats going on here? Im stock height, not lifted not lowered.
1998 Grand Cherokee 5.9 is the Jeep in question.
JeepFreak1982 is offline
post #2 of 60 Old 10-22-2011, 10:33 PM
gabrod72
The only thing that controls where the axle rides from side to side is your trackbar. Provided your upper and lower control arms are fixed and equal length uppers / equal length lowers, then your backward and forward tire position should be the same on both sides. Only other thing I can think of is check your control arm mounting locations at the unibody and make sure they're not tweaked or something else - maybe check the trackbar brackets also.
gabrod72 is offline
post #3 of 60 Old 10-22-2011, 10:37 PM Thread Starter
JeepFreak1982
I did front lower arms also. Both look the same but i know the length is slightly different. The uppers really cant be confused because they will only fit in the rear upper mounts. Its is however possible i mixed up one of the rear lowers with one of the front lowers and the difference in length is causing the problem. The front axle is in the perfect position though? I have owned the Jeep for over 2 years and never noticed the axle off center before. The control arms are all fixed length front and rear. Is there an inside and outside to the control arm or does it not matter which way they go in?
post #4 of 60 Old 10-22-2011, 11:27 PM
PolkaPower
The track bar is what determines where the axle sits.
PolkaPower is offline
post #5 of 60 Old 10-23-2011, 03:14 AM
Mattertron
Yep Track bar 4 sure...
Mattertron is offline
post #6 of 60 Old 10-23-2011, 06:45 AM Thread Starter
JeepFreak1982
It's not the track bar. Axle is still in the same exact spot even with the brand new mopar bar from the dealer.
post #7 of 60 Old 10-23-2011, 08:18 AM
Technohead
The track bar determine side-to-side positioning of the axle and control arms determine front-to-rear positioning of the axle. It must be something with the track bar.
-Eric
Technohead is offline
post #8 of 60 Old 10-23-2011, 09:22 AM Thread Starter
JeepFreak1982
Say the control arms on one side are longer than the other. Wouldnt that push the axle over to one side also?
post #9 of 60 Old 10-23-2011, 09:24 AM
Ripper3494
no, that would make the axle sit at an angle, meaning ex left side is further forward than the right, track bar is your problem
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #10 of 60 Old 10-23-2011, 09:25 AM Thread Starter
JeepFreak1982
It's gota be a mount then. No way it's the bar itself.
post #11 of 60 Old 10-23-2011, 09:26 AM
Ripper3494
by the way are you looking at it while the jeep is on its own weight or not? if the jeep is on jack stands or a lift the axle will swing to one side during droop some, set it down and it will be centered. i had that problem with a tj, looked at on the lift and was freakin out. then set it down and was like... oh
build thread:
RC vs BDS
post #12 of 60 Old 10-23-2011, 09:28 AM Thread Starter
JeepFreak1982
It's in the driveway on it's own weight.
post #13 of 60 Old 10-23-2011, 09:30 AM
Ripper3494
Is it an adjustable trackbar?
Sent from my DroidX because I should be doing something else
build thread:
RC vs BDS
post #14 of 60 Old 10-23-2011, 09:38 AM Thread Starter
JeepFreak1982
No the Jeep is at stock height no lift or anything and it's a brand new bar from the dealer.
post #15 of 60 Old 10-23-2011, 09:40 AM
Ripper3494
Pop it back off and lay it over your old one and see if its the same
build thread:
RC vs BDS
replacing WK 05 rear center cup holder & rear windshield wiper sfall WK Grand Cherokee & XK Commander Forum 1 07-31-2012 04:40 PM
nocked fron axle out of center? FrankTheDank ZJ Grand Cherokee Forum 5 10-31-2009 10:21 AM
Jeep pulls to one side after alignment. Can the rear axle being off center do this? bjl95mustang ZJ Grand Cherokee Forum 5 10-06-2009 02:44 PM
axle off center stiller ZJ Grand Cherokee Forum 4 03-23-2009 04:54 PM
off center axle - adj track bar for 3"? QuadraTokn ZJ Grand Cherokee Forum 21 03-25-2007 05:01 PM
