rear axle near side seal leaking - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > rear axle near side seal leaking
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 06-28-2007, 09:14 AM   #1
Russ7567
hi can any one help? I have a 99 grand cherokee and i have notice the rear axle near side seal is leaking. Can any one advise on how much of a job it is to replace, I have had a look on the forum and cant find anything. I would much appreciate any help.
Thanks Russ
Russ7567 is offline   Reply With Quote
Unread 06-28-2007, 09:19 AM   #2
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Bearing seal probably failed. You'll need to either have it replaced or do it yourself. You may have hda some damage to the axle and that will also have to be replaced.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 06-28-2007, 09:39 AM   #3
Russ7567
Hunter
Thanks hunter dont supose you know how easy it is to replace? there dosn't seem to be any movement in the wheel or any bearing play.
Russ
Unread 06-28-2007, 10:04 AM   #4
skain8
where exactly are you noticing the leak? what are you identifying as the "near side seal"?
'02 WJ: 4.7L, 5", 44/9, 231HD w/SYE, 35's, Clayton's
'99 XJ: stock
'98 XJ: stolen
231HD build guide
skain8 is offline   Reply With Quote
Unread 06-28-2007, 11:02 AM   #5
Russ7567
hi the oil is leaking out from the drive shaft seal and going all over the emergencey parking barke shoes. This is on rear axle, on the near side (that been passenger side on a right hand drive car as im in the UK)
Russ
Unread 06-28-2007, 01:37 PM   #6
WJJEEPIN
Howdy
This is for a TJ but its the SAME axel and will give you an EXACT description on what it takes to get er done! I have a 99 and am having the same problem. Good luck.
http://www.stu-offroad.com/axle/d30seals/seal-1.htm
Will
99 4.0 DubJ 35MTRs ford 9"
The Hookup
http://www.mallcrawlin.com/forum/showthread.php?t=12701
WJJEEPIN is offline   Reply With Quote
Unread 06-29-2007, 02:13 AM   #7
Russ7567
ThankyouI will give it ago
Russ
Unread 06-29-2007, 07:21 AM   #8
Cebby
Here's my writeup for the rear D35, not the D30 front like the other link provided:
http://www.jeepslimited.com/index.ph...d=22&Itemid=98
Tech Writeups and more...
2000 WJ Laredo 4.0 4x4 Taupe Frost - Clayton LA Front/Rear | IRO 3" Springs + 3/4" KOR | Bilstein Shocks | JKS Discos/Trackbar/Draglink & Tierod | Dual KOR Stabs | Addco Rear SB/IRO Ext Links | Spidertrax Spacers | 265/70R17 Duratrac's on JK 17's | Black Magic Brakes w/Centric Rotors | Akebono Calipers | Griffin Rad | K&N Drop in | Magnaflow Cat & Muffler shorty setup | Diehard Platinum (Odyssey) | RB1-NAV-Sirius-Chg-iPod | OEM Tow Hooks F/R | 04 Lower Dash, Grille & Seats | Deambered F & R
Coming Soon - Boatside/Sliders, Hidden Winch
Cebby is offline   Reply With Quote
Unread 06-29-2007, 12:17 PM   #9
WJJEEPIN
My bad. Assumed it was the same. Good writeup.
Will
The Hookup
Unread 07-03-2007, 10:45 AM   #10
Russ7567
Thanks great wright up, mines not as bad as that only showing oil on the rear of the disc cover.
cheers Russ
