rear aussie locker + difference in tire tread = potential problem? - JeepForum.com
post #1 of 4 Old 10-05-2008, 07:54 PM Thread Starter
the88thpianoman
2003 WJ
^Not much more to it than that... I had to replace one of my tires due to sidewall damage a while back, so my rear tires have a noticeable difference in tread depth. I've been toying with the idea of finding a used aussie locker, but will an auto locker have any potential problems with the difference in tire tread?
the88thpianoman is offline
post #2 of 4 Old 10-05-2008, 08:08 PM
02COLOWJ
If i'm not mistaken their website says up to 3/8" diameter difference is ok.
02COLOWJ is offline
post #3 of 4 Old 10-05-2008, 08:44 PM
bjl95mustang
bjl95mustang's Avatar
They say 3/8" but I would not push it.
Can you move your front tires to the rear?
I'm guessing you have an open diff. Do some burn outs and wear down the tire. Just swap it to the side that spins.
ZJ 98 5.2 LIMITED De-Badged
4.5" Lift: RE 4.5" springs,Iro rear 3.5 springs+1" spacer, RE shocks, All adjustable arms, IRO front track bar and HD bracket, Rear jks track bar, 1-Ton Steering, 242 tc, 33x12.5x15 GoodYear wrangler silent tires, 15" rock crawler rims, Aussie Locker For My 44A, 760X u-joint front axles.
Soon to come Lock Right Front Locker.
Jeep Inferno member #10
Texas Jeep Club Member #78
bjl95mustang is offline
post #4 of 4 Old 10-06-2008, 06:09 AM
nierace
nierace's Avatar
2003 WJ
Measure the tread depth and see if they're within 3/8" which is 12/32" of each other which is very lenient. Then put the least worn tire with your new one in back. Remeasure them every so often (maybe after 1k the first time) and see which corner wears the fastest and rotate as appropriate.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
Aussie locker problem ... Shinobi ZJ Grand Cherokee Forum 15 11-10-2010 05:57 PM
load noise after rear diff lock installation- aussie locker genislav ronen ZJ Grand Cherokee Forum 15 10-16-2010 02:10 AM
aussie rear locker for 4.7L WJ boyle ZJ Grand Cherokee Forum 17 02-23-2009 07:10 AM
Maximum Tread Difference orimili ZJ Grand Cherokee Forum 11 01-08-2008 11:24 AM
L-R rear tire tread depth difference -- will this hurt the limited slip diff? jo8243 ZJ Grand Cherokee Forum 9 05-21-2006 03:09 PM
