Rear 12-volt power outlet - JeepForum.com
post #1 of 9 Old 06-21-2009, 07:48 PM Thread Starter
jeeplover93
How can I get the power outlet in the cargo storage area in my Jeep to turn on and off with the ignition? I have my subwoofer plugged into it runs the battery down because it just stays on all the time.
jeeplover93 is offline
post #2 of 9 Old 06-21-2009, 09:39 PM
Mickey_D
One, the power outlet isn't meant to run anything over about 100W so your subwoofer amp might be straining the wiring on it.
Two, your subwoofer amp should turn off and shut down with the head unit.
Three, the power outlet should already be turned on and off with the ignition. Every one I have seen has been.
If the amp is running your battery down, there's something wrong with it.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 9 Old 06-21-2009, 09:50 PM Thread Starter
jeeplover93
Actually, the way I have this sub wired is strange. It's a subwoofer for a normal home theater system. I have it plugged into the poweroutlet through a 400W DC-AC inverter so I can't hook that up the headunits ignition cable.
From experience, I know that the power outlet isn't on an ignition. WJJeeps confirms it. http://www.wjjeeps.com/power_outlet.htm
post #4 of 9 Old 06-21-2009, 10:18 PM
subliminal
1997 XJ Cherokee
Stop ghetto rigging a system and get a new sub. Problem solved.
1997 Jeep Cherokee 4.0 Automatic NP231
subliminal is offline
post #5 of 9 Old 06-21-2009, 10:23 PM Thread Starter
jeeplover93
That's a waste of money I don't have... This works great! I just need it to turn off with my ignition.
post #6 of 9 Old 06-21-2009, 10:48 PM
pauler
You picked the one power outlet that's always on LOL ...
Well in short, you're outta luck ... you can rig a switch (simple on/off) to the power outlet and run that wire all the way to the front of your vehicle and mount the switch somewhere, and always remember to flick it off ... or if you get a cheap amp and subwoofer combo off craigslist, it'll have a remote turn on, that'll automatically turn the amp and subwoofer on and off ... if you get it off craigslist it shouldn't be too much
01' Silverstone WJ Limited
-Debadged, K&N CAI, Quad taillight mod, Yellowtop Optima, 3000 watt stereo setup, Kolak 3' Catback (flowmaster 70 with magnaflow tip and high flow magnaflow cat) with DMH electric cutout, Overland woodgrain wheel
pauler is offline
post #7 of 9 Old 06-21-2009, 11:07 PM Thread Starter
jeeplover93
Yeah, I thought about both of those ideas... I think I will just put a little switch on the dash, next to the ignition.
If you do figure out a way to have it work on the ignition, let me know!
P.S. In the 99-04's, all the power outlets are on all the time. I can charge my phone up front, even when the car is off.
post #8 of 9 Old 06-22-2009, 12:32 AM
Mickey_D
Another way would be to run a tap wire off something you know switches with the ignition (cig lighter?) to a relay in the back. Have that wire activate the relay. Have the relay drive the power coming from the power outlet, through the switched contacts of the relay, then out to the inverter. Voile'. Inverter turns on and off with the ignition.
________________
#4
Mickey_D is offline
post #9 of 9 Old 06-22-2009, 05:47 AM
FDWJ
i would bypass the power outlet altogether, run some beefy wires out to the back from the battery, and switch it with a relay and switch on the dash or link it to an ignition circuit. then you could put a fused distribution block in the back and hardwire your inverter back there. that way you would not have to strain those tiny wires risking fire, and also have a power source ready if you decide to install anything else back there. save the power outlet for charging your phone. thats what i did.
'04 WJ 4.0 Select-Trac with Rusty's 2.5" Lift on 31"s
Firefighter Jeep Club member #99
FDWJ is offline
Rear Cargo Power Outlet SplitPoly ZJ Grand Cherokee Forum 15 05-07-2009 07:36 PM
ZJ power outlet to rear seats 93GrandZJ ZJ Grand Cherokee Forum 9 12-03-2007 06:30 PM
Rear Power Outlet PODWIN ZJ Grand Cherokee Forum 3 04-25-2007 03:06 AM
Rear Power Outlet mrese ZJ Grand Cherokee Forum 0 07-05-2006 09:01 PM
04 GC Rear Power Outlet DellMan WJ Grand Cherokee Forum 0 04-05-2004 08:39 AM
