really, what is this? - Page 3 - JeepForum.com
post #31 of 66 Old 07-16-2013, 08:05 PM Thread Starter
2tall2slow
Neat, very cool product seems like it will cut the testing time in half
2tall2slow is offline
post #32 of 66 Old 07-17-2013, 10:44 AM Thread Starter
2tall2slow
need to test crank sensor. suppose to be on trans bell housing right? seen pics of what it looks like, cant seem to locate. imagine a poor guy, carport, summer heat, climbing up under hood tracing and searching.. Crawlin under and searching from below.. the only spot i feel it may be is impossible for me to get to. plz tell me thats not the case..
post #33 of 66 Old 07-17-2013, 10:52 AM
dellis
2005 WK
Your testing will be done at the connector for the crankshaft position sensor ... no need to crawl under the Jeep. For a 1998, the connector for the crankshaft sensor is located on the passenger side of the engine, near the firewall.
dellis is offline
post #34 of 66 Old 07-17-2013, 11:28 AM Thread Starter
2tall2slow
Thanks dellis, i found connector and traced to sensor.
post #35 of 66 Old 07-17-2013, 11:35 AM
dellis
2005 WK
If it tests bad, or you suspect it is bad, PLEASE let us tell you the "secrets" you need to know in order to replace it. With the secrets, it is a 20 minute task ... without the secrets, it can be a frustrating 2 hours with a bruised and scraped arm.
dellis is offline
post #36 of 66 Old 07-17-2013, 11:46 AM Thread Starter
2tall2slow
10-4.
post #37 of 66 Old 07-17-2013, 06:09 PM Thread Starter
2tall2slow
Unhooked connection to crankshaft sensor, checked points B and C using ohm's.. Getting a zero.
post #38 of 66 Old 07-17-2013, 07:18 PM Thread Starter
2tall2slow
Ok i'm an idiot. I was testing the actual connector to the sensor. So i youtubed dr jeeps instructions. The connector that supplies the sensor with power is what i tested. I got the 5v reading. Checked the ground and got 0.01 ohms. So tell me, does that rule out crankshaft? Remember, it now cranks but doesnt turn over, and my gauges look good. Whats next?
post #39 of 66 Old 07-17-2013, 07:37 PM
ZeeJay1997
No you're not idiot. The you tube video you watched assumed that there is a CEL on with a code for the crank sensor, so they had you check voltage to the sensor.
You need to do the resistance check on the sensor pigtail that Uniblurb posted earlier to check sensor. You said you did that and got 0 ohms, what scale was your meter on?
ZeeJay1997 is offline
post #40 of 66 Old 07-17-2013, 08:48 PM Thread Starter
2tall2slow
I got 0 ohms using 2k. Went to 20k still 0.
post #41 of 66 Old 07-17-2013, 09:13 PM
Uniblurb
Uniblurb's Avatar
So your meter is reading "1" when on the ohm scale and not touching the probes to anything or each other. And we're testing the connector/plug on the sensor itself. So when you touch the black probe to the middle B pin, and the red probe to the C pin (would be the right one with locking tab pointed up), your reading is going to "0"? This would be the same as just touching the probes together while on the ohm scale. If this is the case, and you aren't touching the probes together in the sensor connector itself, you have a completely dead crank sensor!
As already mentioned only go with a Mopar crank sensor and I'm posting a link to the test again just so you can make sure the test was done as explained.
http://www.jeepforum.com/forum/f13/r...l#post15678221
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #42 of 66 Old 07-17-2013, 09:31 PM
dellis
2005 WK
Originally Posted by Uniblurb View Post
So your meter is reading "1" when on the ohm scale and not touching the probes to anything or each other. And we're testing the connector/plug on the sensor itself. So when you touch the black probe to the middle C pin, and the red probe to the C pin (would be the right one with locking tab pointed up), your reading is going to "0"? This would be the same as just touching the probes together while on the ohm scale. If this is the case, and you aren't touching the probes together in the sensor connector itself, you have a completely dead crank sensor!
^^ Wow, you can't get any clearer than that ... follow this advice. Oh, and small typo in which the "middle C" should be "middle B"
dellis is offline
post #43 of 66 Old 07-17-2013, 09:34 PM Thread Starter
2tall2slow
Yep, used that as a reference after zeejay kindly reminded me. Had the ohm meter tell me 0 after testing w/ black lead on middle point and red on far right, thumb tab up. Def going to try one more test tomm. So the zero means its dead, eh? Wait...is that light i see at the end of the tunnel?
post #44 of 66 Old 07-17-2013, 09:34 PM
ZeeJay1997
I believe that's the stupidest question I've ever asked...
post #45 of 66 Old 07-17-2013, 09:48 PM
Uniblurb
Uniblurb's Avatar
Thanks dellis and the typo is now fixed.
The only flaw in my reasoning may be is if his meter shows "0" to begin with rather than "1" with the probes not touching anything. Regardless, the sensor reading should not be the same as when the probes are touched together or it's bad.
BTW 2tall2slow make sure on your meter the black probe is plugged into the black socket marked "COM" and the red probe is plugged into the red socket marked "+" or "V-W-mA". Ignore the red "10A DC" socket or any others which may be on your meter.
Uniblurb is offline
